5400 MFWD noise
/ 5400 MFWD noise #1
OntarioGuy
St Marys, Ontario
Hi there. I just changed the 4 spider gears on the front axle - look to be the same as u-joints. I didn't buy JD ones - they were 7 times the price of ones I picked up at a driveline shop! When in 4WD, and I turn more than about half way, there is a loud sort of clicking noise that appears to be coming from the front tire area that would be the outside tire. To clarify, if I am turning left more than half-way to a full left hand turn, the clicking noise seems to be coming from the front right hand wheel. If I turn right more than half-way to a full right hand turn, the clicking noise seems to be coming from the front left hand wheel. The noise only happens when in 4WD. If I am in 2WD, I can turn as sharp as I want with no noise. It doesn't seem to matter if there is a load in the bucket or not. The noise seems to happen in gravel or on grass. I really can't see it being the u-joints, even if they are not JD. The u-joints were so noisy before I changed them that I am not sure if this is a new noise or not. Any help in diagnosing this would be much appreciated.
/ 5400 MFWD noise #2
Do not know, but wonder if the joints are aligned right? Maybe that is not important.
/ 5400 MFWD noise #3
out of time with other joint?
I have a PDF of the Tech manual you're welcome to, if wanted shoot me your email
Joe
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2017 FORD F550 4X2 S/A SERVICE BODY TRUCK (A67737)
2017 FORD F550 4X2...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
2015 PETERB/ILT 320 6X4 T/A GARBAGE TRUCK (A66091)
2015 PETERB/ILT...
1143 (A63745)
1143 (A63745)
2017 Blue Bird 71 PAX School Bus (A66736)
2017 Blue Bird 71...
