5210 TRACTOR
/ 5210 TRACTOR #1
AGGIE1977
Recently purchased 5210 tractor. hydraulic fluid was low but tried to move tractor a very short distance. tractor seemed to stall. is this a factor of low fluid level?:confused:
/ 5210 TRACTOR #2
you might check fluid levels for sure, might be that the filter needs changed. If that doesnt' help, have the pressure checked. I had some problems with my 5300 when it was hot. the oil would bypass a valve and would have a pressure drop. Was replaced under recall.
/ 5210 TRACTOR
I filled hydraulic to full level, did not seem to change, seems like there is a parking brake or something dragging on tractor. not familiar with smaller tractors, maybe with a shredder and loader, it is too much load. was told by mechanic to loosen bleed valves on brakes, have not had opportunity to try this yet.
2018 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2018 Kenworth T800...
2013 Chevrolet Tahoe SUV (A64557)
2013 Chevrolet...
2021 CATERPILLAR 349 EXCAVATOR (A65053)
2021 CATERPILLAR...
2001 FREIGHTLINER FLD120 T/A 6X4 DAY CAB (A67147)
2001 FREIGHTLINER...
SARLO (A64557)
SARLO (A64557)
2022 EZ-GO ELITE...
