When turning the key, the starter will not engage. However, if I bypass or jump the starter relay it does engage the starter.
Things I have tried:
If anyone has advice, please chime in.
- I checked the fuses and they are all good. This model does not have a fuse for the starter relay, which I see a lot of reference to in other posts.
- I did not disconnect the temp switch / sensor as I'm not blowing fuses like many others have described.
- Tried a new starter relay and still have the same problem.
