3-Point Hitch 5203 3 point hitch problem
/ 5203 3 point hitch problem #1
JKNY
Central NY 13084
JD 5105 mfwd, ford 4000,960,NAA, Oliver 770
I have a 2006 5203 with approx. 135 hrs on it. It is used primarily for haying, with not much 3 pt hitch work. Recently I tried to lower the 3 pt. hitch and it would not lower. I checked the "rate of drop" valve and it was open halfway. Yesterday I decided to take that "rate of drop" valve off aand see if I could find anything wrong to cause this problem. When I removed the valve I got some hyd. oil leaking out and the lift arms dropped. I replaced the valve , started the tractor and tried the 3 pt. It lifted fine, but once again the lift arms stayed up . I removed the rate of drop valve again, leaked a little more oil, and tried with the needle valve for the rate of drop removed with the same results. This leads me to believe that my problem is elsewhere , not sure what to try next. Has anyone else had similar problems with these 5x03 tractors , and if so what did it take to fix it? I may call the dealer for advice Tues. It makes me mad in a way because this condition was probably there last year when I put the tractor away for the winter, and I didnt notice it as I didnt use the 3 point at all last fall and my warranty expired last Dec. Thanks in Advance.
/ 5203 3 point hitch problem #2
it could be a number of things. i agree with you about calling your dealer and running the problem by him. this seems to be a common problem with the older 5x03 tractors(2003-2007) but once this problem gets fixed you never hear about it again. did you change your hyd filter during the 100 hour service?
Thanks for your reply. I had not heard of this problem before on these tractors. Other than this I am satisfied with this tractor. Filter changed last spring approx 80 hrs.
/ 5203 3 point hitch problem #4
The 3 point problem with the 5X03 seems to be relatively common. It seems to be a quick fix, but it can be frustrating.
D.
Thanks for answering.I wonder just what causes this problem and what it would take to fix it. I havent had a chance to call the dealer yet.
/ 5203 3 point hitch problem #6
My 2005 5103 did the same thing, the mechanic said some trash around the piston caused the piston to lock? it cost me about $100 to fix. he said it is common w/ these tractors but once it is fixed it usually does not happen again. i do not know where the trash came from, i changed the filter @ 100 hrs and the tractor has only 160 hrs on it. the fluid looked clean too. mine stayed up and would not bleed down at all. i'm sorry i can't give you more detail i wasn't there when he fixed it. i,m guessing the trash had something to do with break in but i am not sure.
/ 5203 3 point hitch problem #7
Can you show me a pic of the area where the valve is. Is it the one under the seat or the lever valve under the tank??
/ 5203 3 point hitch problem #8
2005 JD 5203 My problem is the 3 point arms won't go down. I have taken the end of valve off under the right side of the seat--where rate of drop adj. is. I could see nothing dirty or broken here. did this twice--same results---still won't go down. With end of valve off & slowly letting the arms down manually, they will go down---oil is forced out of rate of drop adj. valve hole. There is no problem with it raising & picking up an implement
/ 5203 3 point hitch problem #9
I have the same year 5103. Had same issue. Dealer took it apart and it had some trash in it. Cost about $250. Said it was common in the 03 series.
/ 5203 3 point hitch problem #10
Maybe being an India build? Wonder if there is a screen filter that picks up that trash? or where that trash resides?
/ 5203 3 point hitch problem #11
Not sure India build matters-still JD tech and manufacturing. There is a screen that picks it up, but apparently did not work well. Have not had the problem again and it’s been 10 years. I was incorrect on the cost-was about $100 to fix. $250 with transporting tractor.
2019 KENWORTH T680 6X4 T/A SLEEPER TRUCK TRACTOR (A59910)
2019 KENWORTH T680...
14ft Flatbed Truck Body (A59228)
14ft Flatbed Truck...
John Deere 5045E for sale
John Deere 5045E...
159119 (A60430)
159119 (A60430)
2024 John Deere 835M Gator (A63116)
2024 John Deere...
2021 John Deere 5230L Applicator (A63109)
2021 John Deere...
