Feb 10, 2015 / 5203 2wd front tires #1 B britej New member Joined Jan 5, 2009 Messages 2 Does anyone know if I can run a 10.00x16 on the front of a 2wd 5203? The stock tires are 7.50's and I am looking for a wider option with the loader. The manual doesn't say.. and there seems to be little room between the tire and the spindle.
Feb 11, 2015 / 5203 2wd front tires #2 P pmsmechanic Elite Member Joined Dec 6, 2013 Messages 4,447 Location Southern Alberta, Canada Tractor 4410 and F-935 John Deere, MF 245 Can you reverse the rims? Or get some different rims with enough offset. You should really have wider rims anyways with a 10.00 tire.
Feb 11, 2015 / 5203 2wd front tires Thread Starter #3 OP B britej New member Joined Jan 5, 2009 Messages 2 I believe the wheels can be turned. I will check when i get home. I may need to back up to 9.50
Feb 11, 2015 / 5203 2wd front tires #4 D dieselbeef Gold Member Joined May 6, 2010 Messages 273 Location myakka city Tractor bx2200..jd 2010 loader backhoe tractor backhoe tires
