5203 2wd front tires
   / 5203 2wd front tires #1
britej
Does anyone know if I can run a 10.00x16 on the front of a 2wd 5203? The stock tires are 7.50's and I am looking for a wider option with the loader. The manual doesn't say.. and there seems to be little room between the tire and the spindle.
   / 5203 2wd front tires #2
Can you reverse the rims? Or get some different rims with enough offset. You should really have wider rims anyways with a 10.00 tire.
I believe the wheels can be turned. I will check when i get home. I may need to back up to 9.50
2010 Ford Crown Victoria Sedan (A51694)
2010 Ford Crown...
1993 Ford F-150 Pickup Truck (A52377)
1993 Ford F-150...
2017 KENWORTH T4 CONCRETE MIXER TRUCK (A51243)
2017 KENWORTH T4...
Pallet of Misc Fabrication Steel (A52384)
Pallet of Misc...
2017 Isuzu NRR 22ft Box Truck (A51692)
2017 Isuzu NRR...
2022 Weber MT CF2A Plate Compactor (A51691)
2022 Weber MT CF2A...
