Backhoe 511 backhoe subframe
/ 511 backhoe subframe #1
Bobvt
Westford, Vermont
Mahindra 6500, Mahindra mPower 85, LS XP8084CPS
Does anyone in Vermont, New Hampshire or northern New York have a subframe mounted 511 backhoe mounted on a 6500, 6000 or 5500 tractor I could come and look at? What I'm really interested in is the subframe part that mounts to the backhoe. I'll curious whether this mount can be adapted to other makes of backhoes (looking at a Bobcat 811 hoe).
Bob
/ 511 backhoe subframe #2
Bob
Bob,
I just looked at my 511 mounts. Since the 511 BH uses 8 bolts to mount the BH half of the subframe, I would say a simple (thick) adapter plate can me mfg. and used. At the most a good welder would be needed to mod the BH half of the subframe.
Keep us posted!
hugs, Brandi
/ 511 backhoe subframe #3
Bob
Bob,
I just looked at my 511 mounts. Since the 511 BH uses 8 bolts to mount the BH half of the subframe, I would say a simple (thick) adapter plate can me mfg. and used. At the most, a good welder would be needed to mod the BH half of the subframe.
Keep us posted!
hugs, Brandi
Brandi,
Thanks for the information. It sounds encouraging. I'm still hoping to see one up close before I make the commitment.
Bob
jpm,
I'd like to see your setup. Is there any chance I could look at it tomorrow afternoon?
Bob
/ 511 backhoe subframe #7
Bobvt said:
Brandi, Thanks for the information. It sounds encouraging. I'm still hoping to see one up close before I make the commitment.
Bob
Certainly using the Mahindra/Bradco subframe would eliminate any questions about strength and appropriateness of design & connection points to the tractor frame. I would certainly take that approach... but only after carefully inspecting the prospective BH and assuring that a suitable adapter plate could be made (as suggested by Brandi) to fit between the removable portion of the subframe and the backhoe. At least on mine, the removable portion of the subframe is essentially two vertical side plates that bolt to the BH and rely on the strength of the BH structure itself for torsional and lateral integrity. Depending on the particular BH selected, this critical "stiffness" would likely have to be provided by the fabricated adapter plate.
Dougster
/ 511 backhoe subframe #8
Dougster
Not sure why you don't go with the Bradco.....Is someone GIVING you the Bobcat hoe?? The Bradco hoe connecting plate bolts up to the hoe...I'm sure you could have one fabricated and welded on to whatever hoe you have...BobG in VA
/ 511 backhoe subframe #9
I had the very same thought. There are used Bradco's all over the place at very decent prices. The hardest part with these used ones (mostly made for skidsteers) is figuring out the mounting... but if you're buying the Mahindra/Bradco subframe anyway... why not go the rest of the way and find a good used Bradco backhoe as well? :confused:
Dougster
A Bradco 611 is my first choice. Been looking for a good used one for four months. I was the high bidder on one on Ebay but the guy notified me 2 days after the auction that he sold it locally. Can't seem to located one in New England or New York. As far a specs go the Bobcat 811 is very close (reach, dipper and bucket pressure). There seems to be more used 811s available than 611s. If the Mahindra 511 subframe (Bradco said the 611 hoe uses the 511 subframe) will mate up (with minimal alterations) to a Bobcat 811, it would be an acceptible second choice.
Bob
/ 511 backhoe subframe #11
Bob
Yeah, there are a lot more used Bradco 509's and 609's around than 511's and 611's. No surprise since a lot of these are coming off skidsteers. But your machine deserves an 11-footer... so I can certainly see where you are coming from. :eek:
Dougster
/ 511 backhoe subframe #12
BOBVT,
I think if you search that Bobcat backhoe you find out that it may have been made by Bradco.
If you post a picture of it I can tell if it will work for you.
Or just bring everything down and I will make it work for you.:)
Rick
Rick,
Thanks for the offer, I sure wish you were closer. I'll keep it in mind though.
The Bobcat 811's do look very similar to the Bradcos, but there are some subtle differences (reach is 3" longer, curl & dipper pressure is 3% less, and skid steer mounting plate looks different).
I still want to see a 511 subframe up close before I made any decisions.
Bob
/ 511 backhoe subframe #14
Bobvt said:
Rick,
Bob
Bob,
I have my BH off for mowing.......and it isn't raining. ;) I just went out in the dark and took some photos. Thanks to modern technology, I am uploading great flash assisted photos as I type. :cool: I hope they help :)
hugs, Brandi
Brandi,
Thanks a million for the pictures. They are exactly what I wanted to do if I inspected one. Could I impose upon you to give me both the horizontal and vertical dimensions of the subframe mounting face (where bolts to backhoe)? On the horizontal I'd like both the outside and inside (between bolting plates). If I have these dimensions, I can tell if I can mount the 511 subframe (hoe part) to a non-Bradco hoe.
Thanks again.
Bob
/ 511 backhoe subframe #16
Bobvt,
I have the Bradco/Mahindra subframe on my 2810 and the plates that connect to the hoe. My hoe is a 3pt mount and I plan on adapting also. I'll be interested to see your project.
/ 511 backhoe subframe #17
Bobvt said:
Brandi,
Thanks again.
Bob
Bob,
Hehe. :D Last night while taking photos, I thought you might ask that. I will measure it this afternoon. :)
hugs, Brandi
/ 511 backhoe subframe #18
Hey, Brandi, can you upload your photos reduced in size? 150KB
will show as much detail on a 17-inch monitor as your 400KB pix.
Some of us can not get broadband access.
...and I love to look at anything related to backhoes and subframes.
/ 511 backhoe subframe #19
dfkrug,
When I save the photos in my computer....I save them as best size for emailing. I have dialup and don't have a problem, it just takes longer to upload and download. It is proberly your browser program. Send me a PM with your email address and I will email them to you at your email address. It should work that way. My Kodak Easyshare program will let me save it at Full size, 75%, 50% & 25% also, best for email, best for web, and Thumbnail.
hugs, Brandi
/ 511 backhoe subframe #20
Bobvt said:
Brandi,
Thanks again.
Bob
Bob,
Now I am confused. :confused: These dimensions are for a Bradco 511 BH. How does that work if you are using a Bobcat 811 BH? Even if the holes were only a half hole off, the rigors of a BH deem tight tolerance holes a must. I figured you would cut off the bolt hole flanges from the BH subframe half and weld on new flanges to fit a Bobcat 811 BH. So, you should measure the Bobcat 811 BH also. 511 BH bolt holes are approx. 23 inch spacing for the inboard holes. Inboard to outboard holes are approx. 2.5 inch spacing. So outside to outside bolt holes are approx. 28 inches. The upper holes to the lower holes are approx. 12.5 inch spacing. Eight bolt holes in all. I measured with a tape measure, thus the approx. measurements. I could give exact measurements in the thundredths, but my 3 foot steel rule is at the hangar, 62 miles away. ;)
4 INCH TOWABLE FLUID PUMP (A67714)
4 INCH TOWABLE...
2021 Jeep Gladiator 4x4 Crew Cab Pickup Truck (A66736)
2021 Jeep...
2021 JOHN DEERE 844L WHEEL LOADER (A64279)
2021 JOHN DEERE...
1999 INTERNATIONAL 2674 T/A DUMP TRUCK (A67714)
1999 INTERNATIONAL...
2014 CATERPILLAR D8T HI-TRACK CRAWLER DOZER (A65056)
2014 CATERPILLAR...
backhoe
backhoe
