5065E fuel lines leaking
/ 5065E fuel lines leaking #1
Lowcountry17
Lowcountry, SC
JD 5065E
My four-year old 5065E's fuel lines are leaking. Does anyone have the specs for the ID/OD on the supply and return lines? Also, any recs on what type of hose to go back with? Definitely don't want to use JD's stuff---these lines are cracking all over, leaking in multiple spots and look awful.
/ 5065E fuel lines leaking #2
Go to your Deere dealer, as the replacement likely will not repeat your experience.. they will also have the size info needed.
The tractor is India-made so may account for the short term life of the lines.
My dealer only had the part numbers for the hoses, no specs. And they said the hose would be the same as what's on it now. Not acceptable. I called another dealership and at least got the specs on the supply line ("he thinks"): 3/8" ID and 96.45 inches. Still no specs for return line. NAPA and Parks Auto had zero diesel fuel lines in stock. So, I reckon I'll try to find some diesel fuel line online: Gates, Parker, any others?
Still need specs for return line if anyone knows.
Thanks.
/ 5065E fuel lines leaking #5
If you look at the other link Tx Jim list the spec which is SAE 30R7.
If you search on 30R7 you find its for low pressure high temp fuel line
30R7-03 is 3/16 ID, -04 is 1/4 ID, -05 is 5/16 and -06 is 3/8
Made by Goodyear and others. And local stores with diesel fuel line should meet the same spec
Thank you.
/ 5065E fuel lines leaking #7
Just go to Superior Diesel in N. Chas..& take a piece w/ you.
Just don't take your pump or injectors there..
2019 International LT625 Sleeper 48 (A62613)
2019 International...
2025 Dingo Ditch Bucket Skid Steer Attachment (A61572)
2025 Dingo Ditch...
2015 GMC 3500 HD 4x4 Crew Cab Pickup Truck (A64194)
2015 GMC 3500 HD...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
2005 C7500 20' Box Truck (A62613)
2005 C7500 20' Box...
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
