5065E fuel lines leaking
/ 5065E fuel lines leaking #1
Lowcountry17
Member
Lowcountry, SC
JD 5065E
My four-year old 5065E's fuel lines are leaking. Does anyone have the specs for the ID/OD on the supply and return lines? Also, any recs on what type of hose to go back with? Definitely don't want to use JD's stuff---these lines are cracking all over, leaking in multiple spots and look awful.
/ 5065E fuel lines leaking #2
Go to your Deere dealer, as the replacement likely will not repeat your experience.. they will also have the size info needed.
The tractor is India-made so may account for the short term life of the lines.
My dealer only had the part numbers for the hoses, no specs. And they said the hose would be the same as what's on it now. Not acceptable. I called another dealership and at least got the specs on the supply line ("he thinks"): 3/8" ID and 96.45 inches. Still no specs for return line. NAPA and Parks Auto had zero diesel fuel lines in stock. So, I reckon I'll try to find some diesel fuel line online: Gates, Parker, any others?
Still need specs for return line if anyone knows.
Thanks.
/ 5065E fuel lines leaking #5
If you look at the other link Tx Jim list the spec which is SAE 30R7.
If you search on 30R7 you find its for low pressure high temp fuel line
30R7-03 is 3/16 ID, -04 is 1/4 ID, -05 is 5/16 and -06 is 3/8
Made by Goodyear and others. And local stores with diesel fuel line should meet the same spec
Thank you.
/ 5065E fuel lines leaking #7
Just go to Superior Diesel in N. Chas..& take a piece w/ you.
Just don't take your pump or injectors there..
2015 CASE 621F WHEEL LOADER (A58214)
2015 CASE 621F...
2025 Swict 60in Bucket Skid Steer Attachment (A61567)
2025 Swict 60in...
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2021 CATERPILLAR CB1.8 DOUBLE DRUM ROLLER (A62129)
2021 CATERPILLAR...
2021 JOHN DEERE 204L WHEEL LOADER (A62129)
2021 JOHN DEERE...
2019 Chevrolet Tahoe SUV (A61569)
2019 Chevrolet...
