5030 blowing headlight bulbs
/ 5030 blowing headlight bulbs #1
razor
Bronze Member
canada
Kubota L 6060(2), L 5740 (1)
I was just curious if anybody else goes through headlight bulbs like I do on my 5030. I only use the tractor for snow and put on approx 300 hrs per season. In a season I will go through about 5-6 headlight bulbs. It is not a big deal but it seems like a lot to me.
/ 5030 blowing headlight bulbs #2
that is a big deal, you need to check what is up with your alternator and distribution system, (Voltage and wiring).
What ever is causing this can be effecting your complete electrical system and could get costly over time.
KennyV
It is strange that is it is only the headlights bulbs, all the other bulbs are still the original ones.
/ 5030 blowing headlight bulbs #4
Check the wiring especially the ground side, check the voltage...
the headlight bulbs have the least resistance and there fore will be more susceptible to voltage spikes originating in the alternator or circuit continuity in the electrical system, I would try to locate the problem because it is frequent enough that there is something common to the failure occurring far to often. KennyV
