5000 series 60" deck blades
/ 5000 series 60" deck blades #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
5000 series 60\" deck blades
Does anyone have a second source for the blades for the 60" MMM on the 5000 series. I ordered a set from the dealer twice, with no success. I can get the part number if that helps.
I've only had this deck off once to clean and sharpen blades, it's a lot tougher to get back on than off, anyone else have that problem and a solution?
Has anyone bought the front blower for a 5000 series?
Curt
/ 5000 series 60" deck blades #2
Re: 5000 series 60\" deck blades
Hi Check out this site..I've bought a bunch of blades from them. they even have "Gator mulching blades" at a great price.
http://mowproducts.itcstore.com/
/forums/images/graemlins/cool.gif
Thanks Mark,
I sent them an email with the Cub part #.
Looks like a good source !
Curt
/ 5000 series 60" deck blades #4
I have had my 5234D for well over a year now and I have yet to find an easy solution to getting the 60" MMM deck back on the tractor. I remove and reinstall quite a bit and it's always a pain.
I want to get the FEL with a toothbar but I am really thinking about getting another 5000 series (probably just a 5252, could probably pick one up for around $6000, I already have the MMM) just to mow with and put the FEL on my 5234D so I won't have to screw around with the MMM. I know you can leave the MMM attached with a FEL but I don't want to do loader work with a MMM attached. There is a Cub Cadet kit to pin the MMM in the raised position, I have it but it's still not high enough.
Thats sort of my scenario, I have a older Ford 1220 with a FEL and I use numerous 3 Pt attachments with it.. I've just used the 5252 to mow, it is an excellant moving machine, a real pleasure to operate.
It's a little comfort to know I'm not the only guy tha needs to use the "plumbing language" whenever I remove/replace the deck!
Curt
/ 5000 series 60" deck blades #6
www.mfgrsupply.com.
They matched the blades on my Cub/Woods deck perfectly. Save about $50+ per blade. If I remember the Cub price was $60-$65 per blade. Mfg Supply was something like $11 each and they are identical. Worth a look?
I'll give them a look. Thanks for the tip and the link!
Oops, looks like the link doesn't work, is it misspelled?
Thanks
Curt
/ 5000 series 60" deck blades #9
Apologies for screwing up that link. And thanks for the correction.
F-450 SuperDuty Flat Bed 4WD (A63688)
F-450 SuperDuty...
2018 Chevy Traverse 3rd Row Seating (A63689)
2018 Chevy...
2010 BMW 128i Convertible Coupe. (A61574)
2010 BMW 128i...
CATERPILLAR 299D2 SKID STEER (A60429)
CATERPILLAR 299D2...
2009 Toyota Highlander SUV (A61574)
2009 Toyota...
New/Unused Mini Skid Steer Mounting Plate (A65583)
New/Unused Mini...
