5000 series 60" deck blades
/ 5000 series 60" deck blades #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
5000 series 60\" deck blades
Does anyone have a second source for the blades for the 60" MMM on the 5000 series. I ordered a set from the dealer twice, with no success. I can get the part number if that helps.
I've only had this deck off once to clean and sharpen blades, it's a lot tougher to get back on than off, anyone else have that problem and a solution?
Has anyone bought the front blower for a 5000 series?
Curt
/ 5000 series 60" deck blades #2
Re: 5000 series 60\" deck blades
Hi Check out this site..I've bought a bunch of blades from them. they even have "Gator mulching blades" at a great price.
http://mowproducts.itcstore.com/
/forums/images/graemlins/cool.gif
Thanks Mark,
I sent them an email with the Cub part #.
Looks like a good source !
Curt
/ 5000 series 60" deck blades #4
I have had my 5234D for well over a year now and I have yet to find an easy solution to getting the 60" MMM deck back on the tractor. I remove and reinstall quite a bit and it's always a pain.
I want to get the FEL with a toothbar but I am really thinking about getting another 5000 series (probably just a 5252, could probably pick one up for around $6000, I already have the MMM) just to mow with and put the FEL on my 5234D so I won't have to screw around with the MMM. I know you can leave the MMM attached with a FEL but I don't want to do loader work with a MMM attached. There is a Cub Cadet kit to pin the MMM in the raised position, I have it but it's still not high enough.
Thats sort of my scenario, I have a older Ford 1220 with a FEL and I use numerous 3 Pt attachments with it.. I've just used the 5252 to mow, it is an excellant moving machine, a real pleasure to operate.
It's a little comfort to know I'm not the only guy tha needs to use the "plumbing language" whenever I remove/replace the deck!
Curt
/ 5000 series 60" deck blades #6
www.mfgrsupply.com.
They matched the blades on my Cub/Woods deck perfectly. Save about $50+ per blade. If I remember the Cub price was $60-$65 per blade. Mfg Supply was something like $11 each and they are identical. Worth a look?
I'll give them a look. Thanks for the tip and the link!
Oops, looks like the link doesn't work, is it misspelled?
Thanks
Curt
/ 5000 series 60" deck blades #9
Apologies for screwing up that link. And thanks for the correction.
2018 Kubota M5-111 (A60462)
2018 Kubota M5-111...
2016 Ford F-250 Warner Service Truck (A61573)
2016 Ford F-250...
2006 TerraGator 8104 (A63688)
2006 TerraGator...
2017 Ford Escape SUV (A61574)
2017 Ford Escape...
208735 (A60430)
208735 (A60430)
Big Tex T/A Flatbed Trailer (A56857)
Big Tex T/A...
