50 Hours Maintenance Question
/ 50 Hours Maintenance Question #11
I can’t find that zerk on my ck3510 either. But even if you have a HSTmodel, you do have a clutch peddle and a zerk underneath the floorboard for it.
/ 50 Hours Maintenance Question #13
When you put your tractor in low, medium or high or when you start your pto, there is a foot peddle on the left side. You also need to depress it to start. That is a clutch peddle. On the bottom of the floor panel where it has a lever it has a grease zerk.
/ 50 Hours Maintenance Question #14
Also I looked at that video but do not have the grease zerk it shows.
/ 50 Hours Maintenance Question #15
Yup, no left pedal on mine. I think I read they removed the clutch on SE models when they switched to electronic PTO engagement.
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
2022 Ligchine Spiderscreed Concrete Screed (A59228)
2022 Ligchine...
2014 International Maxxforce DT (A53317)
2014 International...
SDlanch 12'x20' High End Carport (A60463)
SDlanch 12'x20'...
CK350KW SKIDDED GENERATOR (A60736)
CK350KW SKIDDED...
Iranch IRGC40 High End Mini Golf Cart (A60463)
Iranch IRGC40 High...
