5' or 6' box blade?
/ 5' or 6' box blade? #1
hot110ff
Stahlstown, Pa.
John Deere 3720
I will be buying a box blade soon for my Deere 3720 and am not sure what size to get. The tractor has the 43 hp motor and loaded tires. Sure the six foot one will cover more area per pass but I'm not sure if the machine is big enough to drag a 6' one around.
/ 5' or 6' box blade? #2
I think you should be fine with a 6'... the JD 790 (30 or 27 hp) is rated for a 5' box blade... You definately want it big enough to cover your tracks
Brian
/ 5' or 6' box blade? #3
Go with a 6'.. my 27hp 1952 ford 8N pulls a 5' fine...
soundguy
/ 5' or 6' box blade? #4
Go with the 6ft. My JD 3320 pulls a Woods 5 1/2 box blade just fine.
/ 5' or 6' box blade? #5
I ran a 5 footer behind my L2800 which was no problem (+/-28 hp). I just bought a 6 footer... man is that BIG. Hopefully, I will pull it (I might have to take smaller bites) not worried about it too much.
/ 5' or 6' box blade? #6
I used a 6' behind my 1964 Ford 2000 for years without any problem. By the way, both are for sale, check the classifieds. I intend to buy a 7' BB to use with my 42 HP Mahindra 4X4. That will be 6" wider than my track, allowing me to get closer to things. But, have got to sell the old Ford first :eek: $$$.
/ 5' or 6' box blade? #7
go with the 6' -- 43 HP is plenty to move it around and you'll be glad that it covers your tire tracks -- otherwise you'll never get things to level out right, because one tire will be sitting on a ridge.
/ 5' or 6' box blade? #8
Mornin Erik,
My vote goes with your reccomendation ! ;) :)
/ 5' or 6' box blade? #9
I've run a LandPride 8 foot heavy duty box blade on my 43 hp Ford 2120 for 20 years and love it. The 2120 may be a larger frame tractor, but I would certainly not go with a narrow 4 foot and would consider an 8 footer.
Andy
/ 5' or 6' box blade? #10
I have a 45 hp 4wd tractor and my 6' Bush Hog box blade is just right. I think it would pull a 7 footer with ease but the 6' is exactly the width of my rear tires and for my trails and woods roads that's perfect for me. If I was doing everything out in the open, I'd consider a 7 footer.
/ 5' or 6' box blade? #11
My L-2800 Kubota pulls the six footer just fine with all the grapple hooks fully extended. It sure will rip up some big rocks in hard soil. I had the same worries since my owners manual says five foot but I am glad I went with six foot since it gives me six inches wider on each tire and I can get up close to the sides of the road or bank.
/ 5' or 6' box blade? #12
Go 6' my, TC 29 can move a lot of dirt and the width, as others have pointed out, is a great advantage. You can't take a great big bite but you don't have a dozer anyway.
Enjoy, Neil
