4wd on BX23 - not working?
   / 4wd on BX23 - not working? #11
</font><font color="blue" class="small">( I also tried raising the back wheels with the BH and they both turn when I hit the pedal. )</font>
Okay, some confusion here. I thought you were using a 3PH back blade and had taken off the BH to attach it which is why I asked about the hose hook ups. But I see from this that the BH is still attatched and is functioning fine so scratch that theory.
Reading the WSM reveals that if resistance to both wheels is equal they will both spin at the same speed. If you put a load on one you could expect the other to turn faster, this is how it compensates for going around corners. When one tire encounters slippery conditions it spins and robs power from the other. This is where the dif lock comes in. It locks both wheels together so (hopefully) the other wheel can get a grip and move the tractor.
</font><font color="blue" class="small">( Any explanation of the how the 4wd should work would be helpful. )</font>
Well, I hope that's helpful, but as for a diagnosis I'm afraid I don't really have any ideas.
Good luck and keep us posted!
   / 4wd on BX23 - not working? #12
   / 4wd on BX23 - not working? #13
Fuel delivery problem? /forums/images/graemlins/confused.gif
Changed your fuel filters yet?
RDnT
   / 4wd on BX23 - not working? #14
RDnT
I believe I found the problem. It finally stopped raining and I was able to take the tractor outside and take a look at it. The rear left rim is spinning inside the tire. The rear tires are filled, so I don't understand why I don't have fluid all over the place, but the seal around the rim must be gone in order for it to spin like that. I'll take the wheel off the tractor and bring it over to the dealer.
Thanks for the suggestions.
   / 4wd on BX23 - not working? #16
So in 2WD, the tractors not even moving much? I think you need a little more air pressure in that tire. Make sure that with the valve stem at the 12:00 position you are not blowing out pure water when you depress the tire valve. If so, you have to much water. Check the manual for the correct tire pressure.
   / 4wd on BX23 - not working? #17
</font><font color="blue" class="small">( The rear left rim is spinning inside the tire. )</font>
Well I would never have guessed that! /forums/images/graemlins/blush.gif /forums/images/graemlins/grin.gif Maybe it was only supposed to be filled. I, for one, am looking forward to what they have to say about it. /forums/images/graemlins/confused.gif
   / 4wd on BX23 - not working? #18
The fluid has gotten between the rim and the bead causing the tire to lose its grip on the rim. The air pressure is keeping it seated.
I have heard of this happening on larger equipment. They may have to empty the tire wash it off dry it out and refill it.
   / 4wd on BX23 - not working? #19
</font><font color="blue" class="small">( The fluid has gotten between the rim and the bead causing the tire to lose its grip on the rim. The air pressure is keeping it seated.
I have heard of this happening on larger equipment. They may have to empty the tire wash it off dry it out and refill it. )</font>
Ahhh! This makes sense now, thanks for the explanation!
   / 4wd on BX23 - not working? #20
I have a hard time believing that some water or a bunch of water for that matter would allow it to slip. When we mount tires we use soap and water to mount the tires, inflate them and drive off. Granted the air pressure is higher. I would double check the pressure with a low pressure gauge.
UNUSED FUTURE 32" HYD TILTING BUCKET (A52706)
UNUSED FUTURE 32"...
2019 Toyota Corolla Sedan (A55853)
2019 Toyota...
CATERPILLAR 30 1/2" PIN ON BUCKET (A52706)
CATERPILLAR 30...
2024 COLEMAN MINI BIKE (A58375)
2024 COLEMAN MINI...
2020 Husqvarna YTH22V46 46in Riding Mower (A56859)
2020 Husqvarna...
FENCE PANELS (A58214)
