4wd not engaging
/ 4wd not engaging #1
oneparsec
Hello everyone: have 40hp Mahindra and the 4wd won't engage when moving lever to 4wd. Any suggestions a to where to start looking. Thanks
/ 4wd not engaging #2
Try rock tractor...turning wheels back forth..tractor has front loader down pressure until front wheel off the ground.
/ 4wd not engaging #4
Any resistance on the lever? I would start by crawling under the tractor and check the linkages.
/ 4wd not engaging
Thank you for the suggestions. I'll check them out.
/ 4wd not engaging
No, lever moved but no engagement
/ 4wd not engaging
Broken roll pin? If lever is moving and not engaging.
I looked under the tractor. Linkage attached. Should i unhook the linkage and try turning the shift manually. With tractor off of course.
/ 4wd not engaging #8
If your linkage is moving the shaft like it is designed to, I would next uncover your driveshaft and gearbox output shaft and examine -Some simple testing here will allow you to determine if the issue is in the gearbox vs driveshaft vs front diff/axle
/ 4wd not engaging
Okay, good idea. thank you
/ 4wd not engaging #10
Use the bucket to lift the front end, then see if it engages.
/ 4wd not engaging #11
Good idea to take the load off the front end.
2019 Ford F-450 Knapheide Service Truck (A66736)
2019 Ford F-450...
2025 Swict 66in Tooth Bucket Skid Steer Attachment (A66734)
2025 Swict 66in...
2010 Honda Civic Sedan (A66738)
2010 Honda Civic...
2008 FOREST RIVER CARDINAL 30RK 5TH WHEEL (A65643)
2008 FOREST RIVER...
CATERPILLAR ENGINE (A67714)
CATERPILLAR ENGINE...
Skidded Fuel Cell (A67714)
Skidded Fuel Cell...
