4wd not engaging
/ 4wd not engaging #1
oneparsec
Hello everyone: have 40hp Mahindra and the 4wd won't engage when moving lever to 4wd. Any suggestions a to where to start looking. Thanks
/ 4wd not engaging #2
Try rock tractor...turning wheels back forth..tractor has front loader down pressure until front wheel off the ground.
/ 4wd not engaging #4
Any resistance on the lever? I would start by crawling under the tractor and check the linkages.
/ 4wd not engaging
Thank you for the suggestions. I'll check them out.
/ 4wd not engaging
No, lever moved but no engagement
/ 4wd not engaging
Broken roll pin? If lever is moving and not engaging.
I looked under the tractor. Linkage attached. Should i unhook the linkage and try turning the shift manually. With tractor off of course.
/ 4wd not engaging #8
If your linkage is moving the shaft like it is designed to, I would next uncover your driveshaft and gearbox output shaft and examine -Some simple testing here will allow you to determine if the issue is in the gearbox vs driveshaft vs front diff/axle
/ 4wd not engaging
Okay, good idea. thank you
/ 4wd not engaging #10
Use the bucket to lift the front end, then see if it engages.
/ 4wd not engaging #11
Good idea to take the load off the front end.
2025 Kubota SVL75-3HFWCC High Flow Cab Track Loader - 70 hours
2025 Kubota...
GENIE GS-1930 ELECTRIC SCISSOR LIFT (A62129)
GENIE GS-1930...
1996 Great Dane 50' x 102" Reefer Trailer (A62613)
1996 Great Dane...
SHOP BUILT TRI-AXLE LOWBOY TRAILER (A63291)
SHOP BUILT...
2018 CATERPILLAR D6T XL HIGH TRACK CRAWLER DOZER (A62129)
2018 CATERPILLAR...
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59905)
2018 FREIGHTLINER...
