4WD DASHBOARD LIGHT NOT WORKING
   / 4WD DASHBOARD LIGHT NOT WORKING #1
JasonMac
NH
John Deere 3720 Cab Tractor
I just noticed yesterday that when I engage my 4WD Lever on my Cab tractor that it is not lighting up on the dashboard.
The Tractor is engaging 4WD, and the actual Lightbulb does work, because when I turn the machine on it lights up for 3 seconds along with all of the other dashboard light indicators.
It's not a big deal, just wondering if anybody knows what might be a quick fix to remedy this.
See, I loaned my tractor to the guy that was putting in brick walkways at my mothers house. I just went down and grabbed the tractor back yesterday afternoon and noticed the light doesn't light up when put in 4WD.
Like I said, it's not a real problem, but it would be nice to have it still light up, because I know the bulb works.
   / 4WD DASHBOARD LIGHT NOT WORKING #2
The MFWD light is activitated by a switch. Check that the harness attached to the switch isn't damaged or disconnnected. The switch should be on the left side of the transmission under the footdeck. Look for the lever on the transmission that moves when the MFWD is turned on and off and there should be a switch near by (probably above the lever).
500BBL WHEELED FRAC TANK (A58214)
500BBL WHEELED...
John Deere S660 Combine (A59814)
John Deere S660...
2012 Ford Transit Connect Van, VIN # NM0LS7DN0CT092703 (A57453)
2012 Ford Transit...
2010 Club Car Precedent Electric Cart (A56859)
2010 Club Car...
Landoll 7130 Harrow (A59814)
Landoll 7130...
2017 Ford Fusion Hybrid Sedan (A56859)
2017 Ford Fusion...
