Four Wheel Drive Indicator
/ Four Wheel Drive Indicator #41
/ Four Wheel Drive Indicator #42
That didn't have anything to do with brakes, only 4WD.
Understood completely, simply crying about my own issues!
A bright green LED has been mounted in the dash slighty above the headlight switch assembly. The LED is visible in the Alabama sunshine. A wire has been run from the LED to the front wheel assist lever and onward to the accessory power under the seat. I am now waiting for a limit switch, with a roller, from Amazon.
/ Four Wheel Drive Indicator #44
I got around to installing a sensor and light to indicate I’m in 4x4 on my L 3901, need to print a 4x4 label for next to the light.
My brother and I used a lever arm momentary limit switch. The switch is wired to be normally closed. The switch is mounted so that in 2WD the lever is in the open position therefore no LED. When the FWD control is moved, the switch closes and the LED is on.
The LED is mounted near the headlight control on a Yanmar SA425. The LED is visible even in the bright sunshine of south Alabama.
/ Four Wheel Drive Indicator #48
I have a Caseih Farmall 55c/ LS which already has a light in the gauge cluster as it lights up momentary during startup along with a two wheel drive light. Does anyone know which pins to use in the cluster and how difficult is it to get to the dash cluster?
1965 PS2824SP 28FT 15 Ton Flatbed Trailer (A59230)
1965 PS2824SP 28FT...
SKID STEER ATTACHMENT MULCHER (A58214)
SKID STEER...
2017 FORD F-450 XL BUCKET TRUCK (A58375)
2017 FORD F-450 XL...
GEARMATIC WINCH CABLE DRUM (A58214)
GEARMATIC WINCH...
2018 Chevy Silverado 1500 4X4 (A61306)
2018 Chevy...
2020 Nissan Rogue SUV (A59231)
2020 Nissan Rogue...
