Four Wheel Drive Indicator
/ Four Wheel Drive Indicator #41
/ Four Wheel Drive Indicator #42
That didn't have anything to do with brakes, only 4WD.
Understood completely, simply crying about my own issues!
A bright green LED has been mounted in the dash slighty above the headlight switch assembly. The LED is visible in the Alabama sunshine. A wire has been run from the LED to the front wheel assist lever and onward to the accessory power under the seat. I am now waiting for a limit switch, with a roller, from Amazon.
/ Four Wheel Drive Indicator #44
I got around to installing a sensor and light to indicate I’m in 4x4 on my L 3901, need to print a 4x4 label for next to the light.
My brother and I used a lever arm momentary limit switch. The switch is wired to be normally closed. The switch is mounted so that in 2WD the lever is in the open position therefore no LED. When the FWD control is moved, the switch closes and the LED is on.
The LED is mounted near the headlight control on a Yanmar SA425. The LED is visible even in the bright sunshine of south Alabama.
/ Four Wheel Drive Indicator #48
I have a Caseih Farmall 55c/ LS which already has a light in the gauge cluster as it lights up momentary during startup along with a two wheel drive light. Does anyone know which pins to use in the cluster and how difficult is it to get to the dash cluster?
Location Tampa, FL (A61567)
Location Tampa, FL...
1995 Freightliner FL70 Fuel Truck (A62613)
1995 Freightliner...
Landhonor Skid Steer Bale Spear, Dual Spear  (A62679)
Landhonor Skid...
3 Point Plow (A62613)
100 GALLON ALUMINUM TRANSFER TANK (A64277)
100 GALLON...
GMC 2500HD 4wd Service Truck (A63689)
GMC 2500HD 4wd...
