4WD DASHBOARD LIGHT NOT WORKING
   / 4WD DASHBOARD LIGHT NOT WORKING #1
JasonMac
NH
John Deere 3720 Cab Tractor
I just noticed yesterday that when I engage my 4WD Lever on my Cab tractor that it is not lighting up on the dashboard.
The Tractor is engaging 4WD, and the actual Lightbulb does work, because when I turn the machine on it lights up for 3 seconds along with all of the other dashboard light indicators.
It's not a big deal, just wondering if anybody knows what might be a quick fix to remedy this.
See, I loaned my tractor to the guy that was putting in brick walkways at my mothers house. I just went down and grabbed the tractor back yesterday afternoon and noticed the light doesn't light up when put in 4WD.
Like I said, it's not a real problem, but it would be nice to have it still light up, because I know the bulb works.
   / 4WD DASHBOARD LIGHT NOT WORKING #2
The MFWD light is activitated by a switch. Check that the harness attached to the switch isn't damaged or disconnnected. The switch should be on the left side of the transmission under the footdeck. Look for the lever on the transmission that moves when the MFWD is turned on and off and there should be a switch near by (probably above the lever).
yellow ball Trailer (A56859)
yellow ball...
2019 Grove TMS500-2 40T Crane (A60460)
2019 Grove...
TANK MANIFOLD (A55745)
John Deere 3025E (A53317)
John Deere 3025E...
MACK T/A DUMP TRUCK (A60430)
MACK T/A DUMP...
INTERNATIONAL EAGLE ROAD TRACTOR (A52707)
INTERNATIONAL...
