48x39x14 shop build
   / 48x39x14 shop build #171
ovrszd,
All this talk about garage doors, I lost my head a bit and forgot to tell you how great your shop is. I agree with Citydude, I love the ceiling too. My general shop is 28x32, wood shop is 20 x 20 and metal shop is 12x28. All walls have 1/2" OSB covered with 1/2" drywall. Like everyone says, should have made it bigger. I love the industrial look of galvanized conduit. I had the electricians wire my mechanical room with conduit.
   / 48x39x14 shop build #172
I don't remember what model mine are. They are much heavier duty than Ed's. My Son has three like Ed's, they work fine on his 10x10 doors.
Friend of mine is building a large shop. They are using Liftmaster units similar in size to mine. But they turn the torsion spring shaft via gears and a bicycle chain. They mount on the wall a couple feet below the shaft. They also use a "buggy spring" looking affair that puts downward pressure on the doors when they are full open. They are 10x12 doors.
I have that buggy contraption on my small door, I think because it is only 7'H x 8'W and I wanted it to and track against the ceiling. It angles away from the wall, then curves, goes level with the ceiling and bumps the buggy spring thing. The two 10'Wx9'H doors do not have this contraption.
But whats up with the two plumbing 45's?
Had to think for a minute. To get the conduits to pass I had to use 45s. Poor planning on my part...
Yes, my doors are 10'W x 9'H. My ceilings are 10' as I have a 2 bdrm apartment above. I never heard of a slack issue with the cable. I have a cable tensioner thing on each door cable that is connected electronically into the system. To be honest, not sure what it does, if anything but I do remember the installer mentioning it. Looks like you could have done the LJ8900W for up to 180 Sq Ft of door.
The tensioner detects slack and slows the opener to prevent a tangle.
   / 48x39x14 shop build #175
These are my first. I am impressed with the quality. Well sealed at the panel joints. Really like the rollers. Smoothest operating doors I've owned. I'd have to look for certain, but I think they were just under $2K each.
When I bought my first pair in Austria... I was taken back on the price... but, then everything costs more there... then I really took a look and began to appreciate the quality... also the design doesn't have pinch points like my sectional in Oakland... the entire door and opener operate smooth and quiet... plus weatherstriped and insulated.
   / 48x39x14 shop build #176
I am very early in building a shop. Finalizing dirt work soon. So what is cheaper about conduit? I kinda want to use it, but didn't want to spend extra for no real reason.
   / 48x39x14 shop build #177
How did you go about running all the wire?
Ran it as your hung the conduit?
Pushed it through after conduit was hung?
Pulled a string?
I am doing all exposed conduit in my shop also, simply for the easy access and ability to change things, plus I love the look.. I’m going with white tin walls also.
   / 48x39x14 shop build #178
pull the string with a vacuum cleaner. pull the wire with the string.
   / 48x39x14 shop build #179
Conduit isn't necessarily cheaper, but it gives you flexibility to change or add to the electrical system very easily. My experience (mistake) as in putting all the wiring behind the OSB on my walls and above the metal ceiling. Now I have all these openings in the walls and ceiling for outlets and fixtures which compromise the insulation and were very time consuming to install. It all would have gone much faster with conduit.
My supplier said it's cheaper to run 3 individual wires than Romax. Said less labor is involved which lowers installation costs. I cannot verify that. I was already leaning toward conduit. That's what I used in my current shop. So I didn't do any price comparison.
2024 JOHN DEERE 4044M LOT NUMBER 65 (A53084)
2024 JOHN DEERE...
New/Unused CFG Industrial MH12RX Mini Excavator (A51573)
New/Unused CFG...
2017 Claas Jaguar 860 Forage Harvester (A53472)
2017 Claas Jaguar...
New/Unused 7ft Stainless Steel Workbench (A51573)
New/Unused 7ft...
BBQ Longhorn Bull Smoker (A51572)
BBQ Longhorn Bull...
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
