Backhoe 48 Backhoe Noise
/ 48 Backhoe Noise #1
Dave4410
Cape Cod
2004 John Deere 4410 eHydro
Lately I've noticed a clanking sound coming from inside the boom of my 48 backhoe. I'm almost certain the noise was not always there. We just hit the 100 hour mark and I grease the hoe regularly. I've not been rough on the hoe, as evidenced by the fact that all of the bucket teeth are intact! There also seems to be more play in the swing than there used to be. Any comments would be appreciated.
/ 48 Backhoe Noise #2
Normal procedure would be to find the motion that makes the noise and keep repeating until you see or localize the problem, preferrably from outside the backhoe swing range for safety. Look for cracks, bends, and missing parts. Removal of debris may be required. SteveV /forums/images/graemlins/crazy.gif
/ 48 Backhoe Noise #3
I had a clanking sound when operatoring my backhoe and it turned out to a bent pin, it was rotating depending on the pressure source.
JD4600 with 460FEL with pallet fork and 7'6" Meyers Snow Plow, JD LX279, 84" KK finishing mower, 84" KK Landscape Box, 84" KK Landscape Rake, 84" KK Blade, and 72" KK Bush Hog, 7' Northern Tool Backhoe, 1956 GMC 10 Yard Dump Truck
Greg
/ 48 Backhoe Noise
Bent pin sounds like a possibility. The sound might be echoeing through the boom. I'll investigate after thge rain subsides tomorrow.
INGERSOLL RAND BLAW-KNOX PAVER (A67714)
INGERSOLL RAND...
2009 Polaris Ranger 700 (A64127)
2009 Polaris...
2012 Gillig G27B102N4 32+54 Low Floor Passenger Bus (A66736)
2012 Gillig...
CAT D6R Straight Blade (A68134)
CAT D6R Straight...
2013 WACKER NEUSON LTN8 LIGHT PLANT (A68842)
2013 WACKER NEUSON...
2011 BRENNER TANK TRAILER (A67714)
2011 BRENNER TANK...
