4720 rat problem
/ 4720 rat problem #1
Philthefridgeman
Cairns queensland
John Deere 4720 cab hydro . Can I install a battery isolator switch as I have rats in my shed and worry about the fire risk. Will turning off the battery effect the computer? Thanks Phil
/ 4720 rat problem #2
Good Morning Philthefrigeman and welcome to TBN. I have a few suggestions.
- keep the hood open on your JD when not in use. I have mice and chipmunks. Neither like the open spaces of an open hood. This seems to be about the best solution - and I've tried most, at least one time. Barn cats are the ultimate answer. If you can keep the coyotes, owls and hawks from eating them.
- your on-board computer for the tractor should have a battery backup to protect the memory. Disconnecting your main starter battery should not affect the computer memory.
2018 Western Star 4900 Tandem Dump (A62613)
2018 Western Star...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2014 FREIGHTLINER CASCADIA (A63569)
2014 FREIGHTLINER...
Schulte Batwing Rotary Brush Cutter Tractor Attachment (A61572)
Schulte Batwing...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
John Deere 2155 Tractor W/ Loader (A62613)
John Deere 2155...
