4720 front knuckle seal procedure?
/ 4720 front knuckle seal procedure? #1
Z RENCH
North Texas
09 Bobcat CT335,09 ct440,08 Kioti DK55, 10 DK45HST, 10 DK40HST, & an 09 John Deere 4720
Does anyone know the proper procedure to replace the knuckle seal on an 09 JD4720? I'm assuming that's what it is called, it is the pivot point where the front wheel turns, not the very outer wheel seal. This seal is about 4" in diameter. Just don't want to take anything apart that I don't have to or anything that will get me into trouble. Any advice is appreciated.
Thanx for thr reply Fuse, but that manuel is for there big sprayer, not the compact tractor. I already replaced the seal in it yesterday. Yoy must remove the knuckle from the axle housing (boy is that thing heavy;)) and then disassemble it on the bench to get at the seal. Glad that's over with!
/ 4720 front knuckle seal procedure? #4
I have the same problem with mine and was going to order parts and do myself. This is the only related post I can find on line. I have a shop and tools but don't work on tractors for a living. Anything special about this job? From the parts brake down, not obvious what holds the knuckle together. Only see the one small clip at the bottom of the spindle assembly on the stub shaft behind the bottom plug. Any help would be appreciated, know this is kind of an old post.
/ 4720 front knuckle seal procedure? #5
EJack11
:welcome: to TBN
Get a copy of the service tech manual for your tractor, and it will help a lot for your job.
/ 4720 front knuckle seal procedure? #6
I have a PDF of the tech manual you're welcome to. If wanted shoot me your email
Joe
/ 4720 front knuckle seal procedure? #7
really good snap ring pliers help , they can be a bear , been there done that
/ 4720 front knuckle seal procedure? #10
??? 4720 CUT and 4720 Sprayer are two totally different beast, I sent you the tractor manual
/ 4720 front knuckle seal procedure? #11
I have done a bunch of those deere and Kubota are very similar , I use to do them with the knuckle still on the tractor laying on my back , that's not the easy way pop the tie rod off and take the 4 bolts out that hold the assembly to the axle housing , and take it to the bench . when ordering the seal also order the bottom plug . you can lighten the assembly by removing the 10 bolts are remove the hub .it has to come off anyway , when you pop the plug out and look its self explanatory snap rings and a gear. the older smaller tractors use a spanner nut with a locking tab washer .
/ 4720 front knuckle seal procedure? #12
Hi Joe, would you be so kind to send me that PDF?
/ 4720 front knuckle seal procedure? #13
Matt
:welcome: to TBN
You best send a PM to Joe with your email so he can send that .pdf.
We'd be interested to hear more about your work on the 4720.. and we like pics too. ;)
/ 4720 front knuckle seal procedure? #14
