4720 front knuckle seal procedure?
   / 4720 front knuckle seal procedure? #1
Z RENCH
North Texas
09 Bobcat CT335,09 ct440,08 Kioti DK55, 10 DK45HST, 10 DK40HST, & an 09 John Deere 4720
Does anyone know the proper procedure to replace the knuckle seal on an 09 JD4720? I'm assuming that's what it is called, it is the pivot point where the front wheel turns, not the very outer wheel seal. This seal is about 4" in diameter. Just don't want to take anything apart that I don't have to or anything that will get me into trouble. Any advice is appreciated.
Thanx for thr reply Fuse, but that manuel is for there big sprayer, not the compact tractor. I already replaced the seal in it yesterday. Yoy must remove the knuckle from the axle housing (boy is that thing heavy;)) and then disassemble it on the bench to get at the seal. Glad that's over with!
   / 4720 front knuckle seal procedure? #4
I have the same problem with mine and was going to order parts and do myself. This is the only related post I can find on line. I have a shop and tools but don't work on tractors for a living. Anything special about this job? From the parts brake down, not obvious what holds the knuckle together. Only see the one small clip at the bottom of the spindle assembly on the stub shaft behind the bottom plug. Any help would be appreciated, know this is kind of an old post.
Thanks
   / 4720 front knuckle seal procedure? #5
EJack11
:welcome: to TBN
Get a copy of the service tech manual for your tractor, and it will help a lot for your job.
   / 4720 front knuckle seal procedure? #6
I have a PDF of the tech manual you're welcome to. If wanted shoot me your email
Joe
   / 4720 front knuckle seal procedure? #7
really good snap ring pliers help , they can be a bear , been there done that
   / 4720 front knuckle seal procedure? #10
??? 4720 CUT and 4720 Sprayer are two totally different beast, I sent you the tractor manual
Ford Super Duty Pickup Truck Bed (A51691)
Ford Super Duty...
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
JOHN DEERE/UNVERFERTH 1700/330 LOT NUMBER 13 (A53084)
JOHN...
2018 KENWORTH T880 DAYCAB (A53843)
2018 KENWORTH T880...
Heavy Duty D-Ring Shackles (A55852)
Heavy Duty D-Ring...
2011 Ford Explorer SUV (A53424)
2011 Ford Explorer...
