Flight controls bolts with locking rings, the castle nut and cotter pin
There is a lot of ignorance on safety wire and safety cable out there
0.032 is to hold it in place 0.020 is there for a visual indicator
I remember my dad doing something like that when I was a kid. It seemed like, after torquing a nut, he would take a punch and dimple a thread on the bolt? I can’t remember the exact process for sure. After getting yelled at for not holding the flashlight correctly, it would cause me to loose interest in the project he was working on. :rolleyes:
Yep, just use a punch to dimple the exposed thread exiting the nut. When the nut is removed it will straighten out the thread by the time the nut is completely removed. I suspect that's where the nylock nut idea originated.
Consider Aviation practice.
I've never had a well snugged lug nut come loose on any vehicle I've ever owned over the past 50 years. Something to be said for tapered seats ;-)
I've never had that happen either but did have all the bolts come loose on the axle hub on both sides of my F250 rear wheels. Came close to ruining both hubs. New OEM bolts and lots of thread locker. Been good since but I still keep an eye on them.
Always been a fan of serrated shoulder or flange nuts and bolts. They stay put with no additional pins or washers. Plus they increase contact spreading the load out some.
If you look at the bottom of a flange nut or shoulder nut, I believe that they have ridges embossed on them that act lock a lock washer and were designed to spread the torque pressure over a larger area than a regular nut or for when there may be clearance issues.
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
2016 Dodge Grand Caravan Van (A59231)
2016 Dodge Grand...
2014 Toyota Tundra Single Cab Pickup Truck (A60352)
2014 Toyota Tundra...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
2017 Chevrolet Equinox SUV (A59231)
2017 Chevrolet...
2013 BMW 328i Sedan (A55853)
2013 BMW 328i...
