I remember my dad doing something like that when I was a kid. It seemed like, after torquing a nut, he would take a punch and dimple a thread on the bolt? I can’t remember the exact process for sure. After getting yelled at for not holding the flashlight correctly, it would cause me to loose interest in the project he was working on. :rolleyes:
I've done that as well but lock tite or a nylon crown nut is easier.
I always thought @MossRoad was a true threadlocker :)
Is Henkel Loctite a mod here?
Henkel is the parent company that owns Locktite and produces the various formulations. The Chinese have jumped on that bandwagon lately. Easy to tell the difference too. The Chinese stuff is a lot cheaper but the formulations are questionable.
The issue with any Nyloc nut is, once used and the insert is deformed by the threads, the nut looses it's locking ability to a great extent. Basically single use nuts. I prefer Castellated nuts and cross drilled fasteners myself.
Chinese stuff tends to be thin like water from what I've seen. Locktite is thick and stays put.
Rocksett and Vibra-Tite are decent alternatives if you can't or don't want to use Locktite brand. Rocksett is particularly good for larger thread diameters.
Castle nuts with safety wire are about as good as you can get. And yeah, nylocs are too cheap to use twice.....
Who here is using Castle nuts with safety wire? I'd guess .001 of the people reading this thread. All my nylon cap nuts are grade 5 or 8. Is that what you mean by cheap?
Not sure I follow? My only point is that safety wired castle nuts are about the best way you can go for securing fasteners. It's aviation standard but absolute overkill for most applications. Nylocs suffice for 95% of applications and distorted thread is good enough for 95% of the remainder.
For the nylocs I'm just saying they're too cheap to risk using one twice after the nylon insert has been deformed. I can't remember the exact number but their holding power is significantly reduced on a second usage. McMaster has grade 5 1\4-20 nylocs for like $5-$6 per hundred last I bought any....
I've used loctite and permatex thread lockers for years, and they've worked perfectly. I was a diver and I worked on ships and subs as a fitter and we used it on most fasteners.
I find that when I used castellated nut a longer bolt was needed because the nut is taller and you still need the min of 3 thread sticking out. So if space is an issue that may not work.
Castellated nuts are for use with cotter pins and a bolt with a hole drilled through it. They have special torque design values because you torque to spec and if the hole doesn't match the nut you back it off untill the hole lines up with the nut.
are you using red or blue loctite?
Do those tires have flat spots? The old big wheel trikes with hard plastic tires always got flat spots where the kids figured out how to lock them up and skid.
Doug in SW IA
Probably already mentioned but in a pinch I have and still use double nuts provided I have enough thread on bolt of course.
A couple years ago I started a thread somewhere about choosing solvents, but it wasn't here at TBN. I did some careful research and came up with answers. Here is my final post in that thread:
I've come to a tentative conclusion. I want to set up easy preferred access to two kinds of solvent, one for the tractor bay in the barn, and the other for the shop indoors (where I also do electronics, handle some laboratory equipment, and other odd stuff).
In the shop I encounter a wider variety of things I need to clean up. There are lubricants as well as whatever grime is on metal stock. But there are also soldering flux, adhesives from labels and gaskets and little assemblies, and contaminants I never know the origin of. For this stuff, acetone is often useful (as many people here also note). But, acetone is pretty polar as solvents go. There is a strategy in creating solvent systems that says you should mix solvents that are pretty different from one another, because the mixture will handle a broader range than any of the single solvents can.
There is a concept known as "Hansen solubility parameters" from a 1967 PhD thesis. You can locate any solvent on a triangular map according to three parameters: the energy from dispersion forces, the energy from dipolar intermolecular forces, and the energy from hydrogen bonds. You can also locate any contaminant on this same triangle. The closer a solvent is to a contaminant in this map, the better it will work. And, a mixture of solvents that are widely spaced on this map will be able to remove contaminants near any of the solvents.
Closest to one point of this triangle are highly polar solvents, which deliver big on the dipolar intermolecular forces. The ketones, including acetone and MEK, are in this direction. Since acetone is cheap in fairly pure form, has fairly low toxicity, and dries quickly with low residue, and like many say is a broadly useful solvent, it's a pretty obvious pick. I could do a little better with acetonitrile but I've never played with the stuff or seen it for sale, so, enough's enough, let's say acetone.
But toward another point of the triangle are things with high dispersion force. Solvents out this way include hexane, white spirits, xylene, toluene, and benzene, the aliphatics and the aromatics. They actually make more effective solvents for petroleum based lubricants and residues from petroleum fuels. Therefore I'm picking something out here to mix with my acetone. Because benzene is so toxic, and xylene is a bit slow to dry and greasy feeling, I'm going with toluene. Nowadays, toluene has a bad name and limited availability because kids tend to use it to get high, but this is here in my own shop where there's nobody to do that, so that's no problem. I also thought of hexane but I'm not sure if it might dry too quickly. And I don't want to analyze this more than is worthwhile. I know toluene and it's satisfactory, so we are going with toluene. I'll say more about white spirits in a bit.
The third point of the triangle is where hydrogen bonding forces predominate. This is where water excels, and the alcohols also do well. Removing salty sweat and grass stains is out in this corner, like various other laundry challenges. But adding a strong hydrogen bonding strength solvent to a system can have negative effects like causing the other solvents to separate out into two phases, and drawing atmospheric water out of the air, encouraging rust and corrosion. And the kinds of cleaning challenges that live here are less often what we deal with mechanically, and more what we hose off in the driveway with Simple Green. Well, I have water and 91% isopropanol and various soaps and detergents conveniently available anyhow, and for some contaminants I'm quick to reach for them, so let's say I have these needs covered already.
Therefore, for my strong, quick drying, low residue, versatile solvent in the shop, I'm going with a 50/50 mix of acetone and toluene. I also found an article that described this blend as an ideal laboratory solvent for dealing with a broad range of unknown contaminants. Sounds pretty good to me. I'm going to fill my new 1 quart plunger can with this in the shop.
Now, about the tractor bay in the barn, let's get back to white spirits. There is more or less of a family of solvent mixtures distilled from petroleum. These petroleum distillates come by different names including paint thinner, naptha, white spirits, Stoddard solvent, deodorized whatever, and even charcoal lighter fluid. They are toward the high dispersion force point of the triangle, but then so are other petroleum products like lubes and fuels, so around a tractor or other power implements they are a pretty useful product. I'm going with a light, deodorized distillate on this one. Safety and cost and availability are all excellent. It will be a bit different from the shop mix (acetone/toluene), so if one system doesn't work well I can take a quick stroll to try the other. This is why I didn't pick the light petroleum distillate for inclusion in the shop mix. Besides, these light petroleum distillates tend to be safer on paints and plastics and other things I don't want to ruin. And they'll be kind to my white shirts (in fact Stoddard solvent was originally made as a drycleaning fluid for nice clothing). This is what I'm putting in the two quart plunger can in the tractor bay. And I'm picking something deodorized. I'm done with using gasoline and kerosene, and stinking all day.
End note: In the 2+ years since, I decided I didn't like the toluene acetone mix because the acetone evaporates out of it more quickly so the mix ratio evolves over time. Therefore I added another plunger can, and keep the acetone and toluene separate in my indoor shop. For out in the tractor bay I'm still happy with mineral spirits, and I can still run back and forth or try isopropyl alcohol or water based detergents as needed.
I have GumBall machines, the easiest way I have found to remove permanent double sides tape off the plastic Globes that attach the product label is a double sided plastic razor blade. they are just like the old Gillett shaving razor blades but made of plastic comes with a handle. the other I found to really loosen it up is to spray rust buster on it and hit it with the plastic blade. works really well. as far as a loctite,I only like the red. it won't loosen up. the way I remove something with the red on it is heat it up a little,loctite melts and softens and comes right out
Carburetor cleaner dissolves any oil or grease and drys very fast is what i use, don't use red loctite if you ever want to take it of, But heat will break it down Hot Heat from a torch!
I tried the carb & brake cleaner,it ruined my globe on my gumball machine
John Deere Mini Decorative Truck (A61574)
John Deere Mini...
2015 Nissan Altima SV Sedan (A61574)
2015 Nissan Altima...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2005 Toro Z Master Commercial 72in Zero Turn Mower (A61572)
2005 Toro Z Master...
2020 CHEVROLET SILVERADO CREW CAB TRUCK (A63276)
2020 CHEVROLET...
2025 70in Rock Bucket Skid Steer Attachment (A61572)
2025 70in Rock...
