4630 synchro adjustments.
/ 4630 synchro adjustments. #1
mamu
Bald knob, arkansas
mitsubishi, case, Kubota, John deere
We have a cab 4630 with the synchro trans on the fender (I guess you'd call it)
So when you come out of park the outside of the drum ill call it moves pretty freely. Then you slide the selector over to say 2/5 gear. Most every time we do that I have to stick a big screw driver in the outside drum and hold it in place to select gear 2 or 5.
Is there an adjustment in the cab for that or is it on/in the trans?
Any help or pointers would be appreciated!
Pic of tractor for fun.
Ok thanks for that. Ill check it in the next few days as its about to get hooked back up to the rake.
2019 K&K Equipment Trailer, VIN # 1K9PE2029KA175459 (A65563)
2019 K&K Equipment...
2021 Kubota MX6000 (A62177)
2021 Kubota MX6000...
2006 JCB 506C HIGH LIFT TELEHANDLER (A62613)
2006 JCB 506C HIGH...
2023 Globe Trailer GTDD30236 36ft. 75yd. T/A End Dump Trailer (A61573)
2023 Globe Trailer...
NEW Wolverine DB-15-84W Snow Blade (A62679)
NEW Wolverine...
2019 Ford F-550 4x4 Altec AT40G 40ft. Insulated Bucket Truck (A64556)
2019 Ford F-550...
