4520R exhaust adequate for pest erradication?
   / 4520R exhaust adequate for pest erradication? #21
pour a quart of common bleach down the hole, then follow it up with an equal amount of ammonia. Then, immediately cover the hole and stay clear of the hole for several minutes, as the combination of the two cleaning agents causes chlorine gas to be released from the bleach. This method has worked quite well for me.If you know where the other end of the tunnel is, block it also. Don't breath the fumes the mixture gives off, as it's chlorine gas and is very toxic. It will attack the mucous membranes in your nose and throat.
Ammonia and bleach combined will produce chlorine gas. Chlorine gas in your lungs combines with moisture and produces hydrochloric acid, also known as muriatic acid. The acid makes the lungs hurt really bad. So the lungs produce fluid to wash out the acid. But the chlorine gas still present makes more acid. A truly horrible way to die. There are much more humane ways to kill.
Eric
   / 4520R exhaust adequate for pest erradication? #22
So far only twelve or so of the nine methods suggestd really sound enough like fun to try. (y)
btw, take my comments with a grain of salt. In ten days I've managed to trap but two chipmunks that were pooping in my barn, one mouse that would have robbed the same bait from their larger traps, and two muskrats that threatened my cattail 'patches'. (AKA welcomed bait-fish cover and wildlife buffer areas)
"You never stand so tall as when you stoop to stomp a varmint." Cartoons Magazine
   / 4520R exhaust adequate for pest erradication? #23
Chipmunks: I used to run a trapline years ago in KS, so I know how to trap. I use live traps around my house and barn for rodents and have seen multiple catches in one setting of a Ketch-All brand spring loaded trap. Chipmunks are too large for those I've got so I've tried a slightly larger wire mesh live trap that also catches rodents easy and can truthfully admit that I've not caught my first chipmunk.
   / 4520R exhaust adequate for pest erradication? #24
Set TomCat black poly snap traps in rat size for chippies, reds, etc in building, barn, or vehicle. Set mouse size alongside to get bait stealing mice or you'll be feeding them and catching nothing. Black oil sunflower seeds don't rot, get moldy, or draw ants but may want to be freshened up every ten years or so. :ROFLMAO: Expect a pound of 'bait' to last two to five before you use it up.
Ignore the bait cup on the pan/trigger and toss seeds into the back of the trap. Full body weight on pan and proper position will usually get 'em in the midsection. Large size traps have holes to tie them to something to minimize crawl-offs and/or theft of catch by hungry critters.
Any trap location that has worked for rodents will have a scent trail leading to it. Keep setting there as roadways develop and others are drawn in. We don't trap the corners where they hide, but at a focal point if out out in the open where they feed. Finding a dead relative inches away in a trap won't discourage or deter a single one from the same fate.
   / 4520R exhaust adequate for pest erradication? #25
When I was highschool and worked at the golf course, we would go at dusk once the golfers were gone, and throw a 100 round pack of black cats into the hole. The concussion and sound would drive them to the surface where we would wack them with a shovel.
It was great, then one day a lady complained and that was that.
   / 4520R exhaust adequate for pest erradication? #26
The poison in spark-ignition engine exhaust is carbon monoxide (CO) which is scrubbed from road vehicles by the emissions system. Diesel engines produce negligible levels of CO. A small, wheeled generator will produce huge quantities of CO that will be very effective on anything that has hemoglobin in its blood including any mammals. Be safe and never, never run a genny anywhere near a dwelling or even upwind of it. CO2, such as dry ice, requires much greater quantities to be toxic.
   / 4520R exhaust adequate for pest erradication? #27
As silly as this sounds, its been used for over 40 years. I don’t have any personal experience with the Juicy Fruit application, but there are several YouTube videos of others using it.
Old wives tale. We tried it in NC with zero results.
"A. This is another one of those urban legends that circulates on the Internet, although this one actually predates the Internet. Using Wrigley’s Juicy Fruit gum for mole (and gopher) control is one of those home remedies that has been passed down from our grandfathers (or grandmothers). Yes, you can find detailed instructions online as to how to apply the gum to moles’ tunnels…but that doesn’t mean it works! It doesn’t."
   / 4520R exhaust adequate for pest erradication? #28
Didn't work for me either.
   / 4520R exhaust adequate for pest erradication? #29
This is incorrect. Gas engines do not have their CO "scrubbed" out by the emissions system. They still produce CO, and it will still kill you if you run a car's engine in an enclosed garage.
CO is nothing to play around with.
   / 4520R exhaust adequate for pest erradication? #30
Actually, yes they do have their CO scrubbed by the catalytic converter which oxidizes it to CO2, and very effectively, with some of the oxygen coming from reduction of NO. These are called three-way catalysts and have been standard for decades now. The tailpipe gases are nearly free of oxygen, however, so it can displace air and kill things by this method, but it's not very potent because of the need for a lot of exhaust gas to get the oxygen concentration in the breathing air down at least below 10%. People have no problem with air down to 15%. But below 10% it gets pretty bad.
On your second point, yes, this does happen with modern cars, most infamously by people who mistakenly leave their car running in their attached garage. CO readily permeates drywall and it has killed people in their main residence rooms in this circumstance. However, the mechanism is oxygen depletion in the garage which makes it impossible for the closed-loop emissions system to add more oxygen by adding more air. In other words, there's not enough oxygen to make CO2, so CO gets made. Take that same car outdoors with its tailpipe poking into a hole in the closed garage (don't try this at home) and there would be little danger.
CO in the wild is deadly which is why portable gennys are so dangerous--they have no emissions systems and properly run with high CO concentrations in their exhaust. Those are nothing to play around with, and not just because of the CO. There's the whole gasoline thing, for example.
   / 4520R exhaust adequate for pest erradication? #31
By all means, go try this.
To every one else, please don't do this.
I think I'm done here.
Good luck Branson owners.
   / 4520R exhaust adequate for pest erradication? #32
Now, I knew when I started reading this thread, I would just have to comment. Growing up, we raised a few hogs and had a corn crib we kept the corn in. Rats would eat all the corn if not controlled. my brother and I used to set on the hill with a couple of 22 rifles and take turns shooting rats when they came out of their holes. One day we wasnt having much luck seeing any rats and we decided to burn them out. We took some gas and simply poured it down the holes and threw in a match. The explosion shook the ground, and a few flames flew out of the holes, which allowed us to find other openings we didnt know about. We decided to pour in some more gas, flooding each hole. This took a few minutes to accomplish. We lit a rag on a stick and threw it at the hole. The ground raised up and blew rats and fire out of the holes, many on fire. Of course, the rats on fire had to try and run away, even tho they didnt make it far, but one critter made it to the corn crib. Lit'l brother and I spent the next few minutes shoveling corn out of the crib to keep it from burning to the ground. We managed to save the crib, and most of the corn. The burnt stuff we hurriedly fed to the hogs so dad wouldnt find out what we had done. Never did see another rat at the crib after that.
   / 4520R exhaust adequate for pest erradication? #33
So your pigs got fire-roasted corn? Very considerate!
S/A Utility Trailer (A59231)
S/A Utility...
207279 (A52708)
207279 (A52708)
Toro Zero Turn Lawn Mower (A56859)
Toro Zero Turn...
2022 CATERPILLAR 249D3 SKID STEER (A60429)
2022 CATERPILLAR...
2004 MACK CV713 MIXER TRUCK (A55745)
2004 MACK CV713...
2018 John Deere Z997R (A53317)
2018 John Deere...
