4520 0r m6040
/ 4520 0r m6040 #4
What will you be using the tractor for and how much are you wanting to spend?
Any attachments on your "must have" list?
Please provide a little info for what your going to use it for. Both are suitable tractors though depending on your needs.
/ 4520 0r m6040 #5
6040 pto HP55 utility
4520 pto HP46.5 compact
This is really going to depend on what you gonna be doing like said above..
/ 4520 0r m6040 #6
I went with the m6040 becuase of the 3pt lift capacity and the extra loader capacity (both of which I needed), but I also needed a tractor small enough to be pulled by a pickup. It fits that niche nicely.
If you are doing much yard/landscape type work, the smaller jd would be nicer for that.
/ 4520 0r m6040
hi all i have a 4520 now . i use the tractor to pull boats and to lift the i/o engines in and out. the boom that i use puts the j/d to the limit . i need a bit more on the hyd end . i tow boats to the river which is down hill so i need good brakes and when i return it,s all uphill so more pulling power can,t hurt
/ 4520 0r m6040 #8
So are you asking whether you should upgrade to something such as the 6040 as an upgrade to your 4520? What kind of a slope is it? Dirt/gravel/paved? How large of boats are they?
From what your saying the 6040 wouldnt provide enough boost for an upgrade.
/ 4520 0r m6040
thanks for the reply the grade is about a 500 ft incline the heaviest boat is around 7500 lbs .
/ 4520 0r m6040 #10
This isn't a real practical application for a compact tractor imo. I would consider a wheel loader or large forklift for this work. I would consider a one ton single wheel truck with a weighted bed and large motor and 4.00 + rear differential for towing.
If you still want a tractor for this type work consider an economy type 6140 Deere. This is a case for a high hp version for what ever frame size you settle on.
It takes lots of hp to pull a load up a long grade at a fast speed. This isn't what farm tractors are designed for, but some of the newer pickups and chassis cab trucks are perfect for this task.
/ 4520 0r m6040 #11
Pretty well nailed it. A tractor in general is just not the most practical in this situation. You will be paying more upfront and more in fuel costs for a compact to a pickup truck and plus you can still drive the truck down the road. At 7500lb you can get a good new or used 2500 pickup to do all of your hauling. Unless you plan to use the tractor for a lot outside of just hauling the boats down the ramp I would get a pickup truck.
/ 4520 0r m6040 #12
My 3/4 ton P/u will haul a fairly large trailer or boat for that matter, In this case where he is likely handling other peoples boats I recommended a one ton so that he could weight the bed reducing slip on slick boat ramps. The one tons are available with the higher numerical rear ends too. Dually p/u trucks seem to have more wheel slip issues on boat ramps in my experience too so I mentioned single rear wheels and would go with 4x4 and limited slip.
Hydraulic Auger Bits Mini Skid Steer Attachment (A61572)
Hydraulic Auger...
2015 Isuzu NPR 16ft. Box Truck (A61573)
2015 Isuzu NPR...
2015 Dodge Charger Sedan (A61574)
2015 Dodge Charger...
2005 Kubota L3130 (A60462)
2005 Kubota L3130...
2018 Dodge Charger (A61574)
2018 Dodge Charger...
2019 INTERNATIONAL LT625 6X4 T/A SLEEPER TRUCK TACTOR (A59912)
2019 INTERNATIONAL...
