Backhoe 448 Backhoe
/ 448 Backhoe #1
Jambone
Dameron, Maryland
John Deere, 4410
I just ordered a 448 BH for a 4410 JD. /forums/images/graemlins/grin.gif I have been trying to find detailed specs on it and/or user manual for it online. Can anyone point me in the right direction. I couldn't find anything on JD's web site. However, I did see that they didn't recommend the 448 for the 4410 tractor, go figure? My dealer said I could use either the 447 or the 448. I'm guessing the web site is not updated regularly and the dealer has information direct from JD saying it's ok to run the bigger BH. /forums/images/graemlins/tongue.gif
/ 448 Backhoe #2
You will be ok,
there are some details that need to be watched:
TRACTOR EQUIPMENT COMPATIBILITY
Tractor applications:
Compatible with 3120, 3320, 3520, 3720, 4120, 4320, 4520, 4720, 4310, 4410, 4510, 4610, 4710, 4300, 4400, 4500, 4600, and
4700 Tractors.
Requirements and/or recommendations:
1) All tractors require tall folding ROPS.
2) Tractors must be equipped with a front loader.
3) A 300X or 300CX Loader is required if the backhoe is used on a 3120, 3320, 3520 or 3720 Tractor.
4) A 400X or 460 Loader is required if the 448 Backhoe is used on a 4510, 4610, 4710, 4500, 4600 or 4700 Tractor.
5) A 400X Loader is required if the 448 Backhoe is used on a 4120, 4320, 4520, or 4720 Tractor.
6) Tractor three-point hitch must be removed for installation.
7) 3120-3720 Tractors require power beyond kit (LVB25505).
8) 4510, 4610, 4710 and 4000 TWENTY Series Tractors require power beyond kit (LVB25512).
9) 4500, 4600, and 4700 Tractors require power beyond kit (LVB25220).
10) 4300-4400 and 4310-4410 Tractors with a 448 Backhoe used in all applications require heavy-duty subframe kit
(LVB24795).
11) Installation of an LVB25628 PRT Oil Cooler Kit is recommended for 4120, 4320, 4520, or 4720 Tractors with a PowrReverser
™ transmission and equipped with a backhoe that will be used for extended periods of time.
12) It is recommended that 4120, 4320, 4520, or 4720 Tractors with PRT be operated at 2100 rpm when using backhoe.
13)A 420, 430, 300X, or 300CX Loader is required for 4300, 4400, 4310, or 4410 Tractors.
14) 4300 and 4400 Tractors require power beyond kit LVB25221.
15) 4310 and 4410 Tractors require power beyond kit LVB25085.
8-ft. 9 in. (2.7 m) digging depth
Quik-Tatch mounting
180-degree swing
Narrow control console
Two-lever control
Six-spool control valve
12-in. bucket
Two double-acting swing cylinders
Operator’s seat with transport locks
Hydraulic stabilizers with flip-over pads
Rockshaft assist mounting brackets, hardware, and adapter
frame plate for 4300-4700, 4310-4710, 4120-4720 and
3120-3720 Tractors
/ 448 Backhoe #3
The 48 backhoe is the one designed for the 4410. They have made the 448 "backwards compatible" for that model as well. The 48 may be going (or gone) out of production, but you should be able to find one. The 48 is a bit more straight-lines and massive in looks, compared to the sweeping curves of the 447/448. Everyone has their own sense of what looks right, but from an aesthetic point of view, I prefer the 430 loader and the 48 backhoe on the 4410. Some will argue that the 300CX loader has more power (marginally) and less view obstruction over the hood (also marginally in my view). I'm glad I got mine before the "aerodynamic" look took over.
/ 448 Backhoe #4
I purchased a new 3320 with the Power Beyond and third SCV for a backhoe. The dealer supplied me with a bungee cord to hold the lever in the rear postion in order to supply the Power Beyond hydraulics. It does work, but does not seem like the right solution. Any suggestions?
EmoTrails
/ 448 Backhoe #5
The backhoe should be plumbed direct to power beyond and not through a SCV. I'm not sure how your third SCV is plumbed but you should be able to get a power beyond connection downstream from it /forums/images/graemlins/smile.gif
/ 448 Backhoe #6
Wow, that's wild.
The power beyond and the 3rd SCV are two different kits, both compatable with each other, and I'm sure for proper
performance of the backhoe you need the power beyond. The return lines on the power beyond dump directly into
the tractor unrestricted, where now with the SCV I'd get there's a lot more restriction of the oil coming out of the backhoe, and could cause for excessive overheating and/or
loss of performance. If the dealer installed this backhoe this way, I'd say he owes you the power beyond.
Let us know what they say..
/forums/images/graemlins/cool.gif
/ 448 Backhoe #7
I am with Dutch! You need that corrected ASAP!!
What backhoe?
If you can, take a pic of the rear of your tractor with the hoe removed, so we can see the fittings...
/ 448 Backhoe #8
Thanks for the input. It's a 447 backhoe. There are two female quick couplers mounted on the machine, which the hoses to the backhoe plug into. They are live when the SCV lever is pulled into the rear position. Midposition the loader operates, and according to the manual, forward position, where the lever will also stay, is "float" - "to remove pressure in both connector lines and allow fuid to flow back and forth between the lines" I actually haven't tried operating the bh in that position since I was told to do it the other way and it worked. I'll check with the dealer about the plumbing and let you know what he says.
EmoTrails
/ 448 Backhoe #9
On the 48 backhoe and a 4410 tractor, the Power Beyond Kit put three hydro outlets at the back of the tractor. When the BH is off, the aux line runs from supply (labeled "A" if I recall correctly) to the return loop ("B") which runs to the rockshaft control and the final outlet ("C") is capped. When the backhoe is attached, the "A" line is connected to the supply side of the hoe, the return line attaches to "C" and "B" is capped. This bypasses the rockshaft controls so that the hoe cannot be inadvertently lifted off its mounts.
The backhoe plumbing on this set up has NOTHING to do with the third SCV.
The system as you have described it seems wrong. You are relying on the float position of the SCV to supply the hydro to the hoe (which it might or might not handle sufficiently) and your rockshaft is not bypassed, which means that you could accidently lift the hoe off its mount and possibly damage the rockshaft arms. If the pins are in correctly, I doubt you could dump the hoe off the back, but I can see where it would put a lot of stress on the rockshaft arms.
I mentioned the models when I started this because things do change, but I cannot imagine that JD has designed a hoe to attach to the SCV when they have a proven workable solution otherwise. I think your dealer either didn't know how to do it, or is trying to pull a fast one on you by selling you what they have instead of what you need.
/ 448 Backhoe #10
this sounds even worse!
are you saying they are using your joystick lever to control
oil flow to the backhoe??
incredible....
/ 448 Backhoe #11
</font><font color="blue" class="small">( this sounds even worse!
incredible....
)</font>
Not the joystick...the 3rd SCV lever...which is a handle next to the rockshaft control. Hey, it's just as bad. They have really screwed with this guy.
/ 448 Backhoe #12
No, not the joystick lever. It's a separate SCV with 3 positions. It will stay in the center or forward position, in which the loader works but not the BH, or it has to be held in the rear position, in which the BH works but not the loader. I returned to the dealer with your thoughts, and he decided that JD must have sent the wrong kit. Indeed all the pictures in the manual for the 447 BH look like what you described - ie having to disconnect a line from the tractor before connecting the BH, and not at all like what JD sent with the tractor. I didn't realize that would disable the rockshaft, but that makes sense too. So, I'll wait for the new power beyond kit and see how it turns out. Thanks again. I'll let you know what happens.
/ 448 Backhoe #13
Attached is a photo of my 447 line hookup, hope it helps. Jeffinspring has described the way mine is .
/ 448 Backhoe #14
ok, you mentioning the loader working and got me all confused..
must be with the scv pulled back to run the hoe, there aren't hydraulics left to run the loader up front...
is this the dealer's first backhoe install??
/ 448 Backhoe #15
</font><font color="blue" class="small">( .....is this the dealer's first backhoe install?? /forums/images/graemlins/cool.gif )</font>
My guess is, "Yes".
/ 448 Backhoe #16
HI again re my 447 backhoe.
John Deere had sent the wrong kit, and since this was obviously the first time the dealer had installed a backhoe on a 3320, they did not recognize it - although all the directions in the manual were illustrated for the correct power-beyond kit. They did get the right kit now and installed it, and all works fine. Thanks so much for your input which got me on the right track.
Phil
/ 448 Backhoe #17
Glad it worked out!
and now, you have the 3rd SCV to boot!
It just shows that we can all learn something every day!
2012 Ford Taurus Sedan (A66738)
2012 Ford Taurus...
PORTA POTTY (A67714)
2019 Mercedes-Benz GLS 4 Matic AWD SUV (A66738)
2019 Mercedes-Benz...
2005 MACK CV713 MIXER TRUCK (A67714)
2005 MACK CV713...
Travel Trailer (A66738)
Travel Trailer...
235/85R16 Tire (A68134)
235/85R16 Tire...
