447 Back Hoe question
/ 447 Back Hoe question #1
cruzr
East Central Missouri
J.D. 3320 / Ford 900
Has anyone used a 24" bucket on the 447? My area is mostly clay, with some rocky areas. Or would I be better off going to a 20' bucket for general digging? The tractor used will be a 3320. Thanks for any advice. /forums/images/graemlins/grin.gif
/ 447 Back Hoe question #2
I am using an 18" HD bucket on my 448. I can take a full bucket of Pennsylvania red clay/soil without any problems. I think the capacities of the 448 and 447 are close. I personally like the 18" bucket. It is narrow enough that you don't have alot of backfill and it is wide enough that you can walk/work in the trench. I would also look into the JD HD series of buckets. They are not that much more $$ than the standard. /forums/images/graemlins/grin.gif
/ 447 Back Hoe question #3
24 is an awfully big bucket for the 447. Even 20 is bigger than I would want for general work. I have a 16 on my 48, which is a bit heavier duty than the 447 and like it just fine. The 12 inch bucket is standard on the 447 for a reason.
Thanks for the 2 reply's, I decided to order the 12" with the BH. Will try it out for a while and see if it has enough power for a 20" or 24" latter. I have a pond that needs to be cleaned out and thought the 24" might be right for.
2013 International DuraStar 4300 Ledwell 2,000 Gallon Water Truck (A61573)
2013 International...
1997 JLG N40 Electric 40ft Articulating Boom Lift (A61572)
1997 JLG N40...
Aluminum Set of Tool Boxes (A62613)
Aluminum Set of...
2003 Chevrolet Kodiak C4500 Flatbed 503372 (A62613)
2003 Chevrolet...
UNUSED CFG INDUSTRIAL H15R MINI EXCAVATOR (A64280)
UNUSED CFG...
2009 Chevrolet Tahoe SUV (A61574)
2009 Chevrolet...
