Not trying to single you out in particular.....because there are several in this thread, but......
Saying "Insert brand here" is a bad tire.......
Its meaningless unless you say what model/type of tire. Michelin (and all the other brands for that matter) make a TON of different tire options. Different treads and compounds for different conditions.
So note to EVERYONE.....if you have a good or bad experience with a particular tire.....dont just mention a brand. Actually tell us what tire you were running.
No offense taken, but after twelve years I don’t remember exact model. I had 95 Chevy half ton. I hated those tires in snow or rain.
I have tried several brands over the decades, all on Powerstroke 3/4 or 1 ton 4x4's, '97, '02, '06 and now '19.
BFG All-terrains: Always liked this tire until I actually bought some, decent traction in snow, ice and thin/soupy mud, not good in thick mud, only lasted about 35K miles though. A little noisy.
Firestone Steeltex was one of my favorites, good all-terrain tire, good in snow, ice and light mud, very durable and long lasting, got about 75K miles each on 2 different sets.
Michelins came on the '06 stock, super quiet, good rain and snow traction, not good in any mud, only lasted about 45-50K.
The '19 has Michelins, super quiet, good snow traction, haven't encountered any ice or significant mud with them yet, only at 21K miles so far.
I have heard great things on the Toyo and Nitto A/T & M/T tires for these heavier trucks elsewhere as well. May try them next.
I remember that. I'm so sick of hearing people say the Ford Explorer was unsafe. I had a 95 two door sport and it was not unstable at all. The problem came with Ford saying to run, it was either 24 or 26 PSI? in the tires. That was what was on the door jam sticker.
And that was the problem with the tires and the roll overs. I always ran 32 PSI in mine and never had an issue.
That's why you saw most of the blowouts and roll overs in the States where the temperatures were much higher than up here.
The tires and time line I was speaking about were 2 decades BEFORE the "firestone-ford-exploder" time period you guys are talking about.
Mine had nothing to do with Fords, or Explorers.
It was the Firestone "721" tires. They were garbage. But they were "OEM" tires on a lot of new cars (like ours) back in the day. Eventually there was a huge class action lawsuit and giant tire recall. It almost bankrupted Firestone (pity it didn't). This was in the 1970's, NOT in the 1990's.
My used F-350 came with a new set of Crosswinds A/T 10-ply tires. Overall, they performed well. Snow traction wasn’t bad, but did leave some excellence on the table. Wet and dry traction was good. They lasted right at 20k miles of on and off road commercial use (landscaping and construction), regularly rotated. Truck weighs 9k, with me in it and usually has a 5k-15k dump trailer behind it and sometimes, hundreds or thousands of pounds, on the flatbed. When they wore down, they got very slick, quickly.
The Crosswinds, new:
After 20k miles:
Here are the General Grabber ATX’s. They have been on 7,135 miles. I checked the tread and I’m running the PSI a little higher than I should. Door jamb states 75 PSI, front; 65 PSI, rear. I’ve been running 5 PSI lower. This was great, on the Crosswinds, but not the Generals. I’ll drop it another 5 PSI and see if that wears better.
The ATX’s are better, in every way. In snow, they are excellent.
New:
After 7k miles:
I also found a nail in one of the front tires, so I’ll get a combo plug patch out in it, in the morning, and rotate the tires.
I had a tbird that had Firestone 721 s. When they issued the recall, I went to the Firestone dealer to take care of it. The dealer replaced all 4 of my fairly new 721s. When I got home, I checked the tires they put on. They were used, almost worn out 721s.
TAYLOR WAY 962 48" HYD TILLER (A57192)
TAYLOR WAY 962 48"...
2021 VERMEER S925TX STAND ON SKIDSTEER (A52709)
2021 VERMEER...
2016 MACK CXU613 MID-ROOF SLEEPER (A58214)
2016 MACK CXU613...
2016 Freightliner M2 106 Ambulance (A59230)
2016 Freightliner...
1990 21ft Center Console Fishing Boat with T/A Boat Trailer (A59231)
1990 21ft Center...
20 LOWBOY BUMPER PULL TRAILER (A58214)
20 LOWBOY BUMPER...
