4410 codes
/ 4410 codes #1
meangreanmashean
Temple, Texas USA
JD 4410 ePowrReverser
Codes 21 and 42. Both forward and reverse travel are cutting out randomly. When tractor does travel in forward it seems to be lacking power, fault code 21. The problems with the forward travel just recently started. Apparently reverse has been cutting out for a while. Since reverse isn't used as much, it never occurred the problem might be bigger than an electrical short or F/R lever not working properly. From what I've read, a pressure test is called for here. As for code 42, I don't exactly remember what took place for this one to pop up. It states in the manual this has to do with the clutch position potentiometer. If that's the case, I'm fixing to be $200 lighter. I could be mistaken, but by fixing this it might take care of both issues. Any thoughts?
Steve
/ 4410 codes
I'm looking for info on ePower reverser. I'm pretty sure the link you posted discussed ehydro.
Thanks,
Steve
/ 4410 codes #4
Code 21 points to a possible bad forward pressure sensor, forward proportional solenoid, wiring problem to one of those items, or a possible internal leak in the forward clutch not allowing enough pressure to engage clutch properly. Code 42 points to the bottom of travel clutch pedal switch or the clutch position potentiometer. Code 42 can be related to forward or reverse engagement problems, but will not cause the code 21 to appear.
Agrotk QA Drop Hammer (A64912)
Agrotk QA Drop...
2100 GAL WATER TANK (A68842)
2100 GAL WATER...
2018 Ford F-750 IMT 6025 7 Ton Crane Mechanics Truck (A64194)
2018 Ford F-750...
1999 Kenworth W14 (A64911)
1999 Kenworth W14...
2024 Kubota L47 T.L.B. 94HRS FOR SALE loaded w/options & $17K off new at $63,900!
2024 Kubota L47...
CAT 930 60" Forks (A68134)
CAT 930 60" Forks...
