4400 dieing on me
/ 4400 dieing on me #1
Tritonman
My tractor has a electrical gremlin or something! It is a 4400 and will start just fine, run up in rpm's just fine but if I try to go forward or backward or try to engage the pto the tractor will die. It must be an electrical thing but am looking for some tips. It had been doing this intermittenly but is not solid. Thanks for the help
/ 4400 dieing on me #2
Sounds like the seat switch. You need to verify the connections to it are tight and the switch is being depressed properly.
As a test, you could jumper acrossed the switch terminals and see if the tractor still dies...I bet it won't.
/ 4400 dieing on me
Kenny, I assume I jump across the wires that run up to the seat from the back. Thanks for the feedback
/ 4400 dieing on me #5
Last time that happened to me I disconnected and reconnected it and worked fine. Must have got a clean connection when I reconnected
/ 4400 dieing on me
Well I tried to rehook and did the jumper trick and it did not work so I am back to the drawing board. There must be a wire getting rubbed somewhere also looking for any other suggestions. Thanks in advance.
2022 East Manufacturing 48ft. T/A Walking Floor Trailer (A66736)
2022 East...
2016 CHVEROLET SILVERADO PICK UP TRUCK (A66091)
2016 CHVEROLET...
2015 KUBOTA F3990 MOWER (A66091)
2015 KUBOTA F3990...
2015 CanAm Commander 800 BRP Side by Side (A62613)
2015 CanAm...
IRanch High-End Tricycle (A64119)
IRanch High-End...
2010 CHANDLER TRI AXLE SPD-18 WATER HEATING TRAILER (A67714)
2010 CHANDLER TRI...
