4400 dieing on me
/ 4400 dieing on me #1
Tritonman
Gold Member
My tractor has a electrical gremlin or something! It is a 4400 and will start just fine, run up in rpm's just fine but if I try to go forward or backward or try to engage the pto the tractor will die. It must be an electrical thing but am looking for some tips. It had been doing this intermittenly but is not solid. Thanks for the help
/ 4400 dieing on me #2
Sounds like the seat switch. You need to verify the connections to it are tight and the switch is being depressed properly.
As a test, you could jumper acrossed the switch terminals and see if the tractor still dies...I bet it won't.
/ 4400 dieing on me
Kenny, I assume I jump across the wires that run up to the seat from the back. Thanks for the feedback
/ 4400 dieing on me #5
Last time that happened to me I disconnected and reconnected it and worked fine. Must have got a clean connection when I reconnected
/ 4400 dieing on me
Well I tried to rehook and did the jumper trick and it did not work so I am back to the drawing board. There must be a wire getting rubbed somewhere also looking for any other suggestions. Thanks in advance.
2010 John Deere 1770NT Planter (A63109)
2010 John Deere...
2011 FORD F-150 (A65643)
2011 FORD F-150...
2017 CATERPILLAR 950GC WHEEL LOADER (A65053)
2017 CATERPILLAR...
2011 PETERBILT 367 (INOPERABLE) (A65643)
2011 PETERBILT 367...
5 SHANK V-RIPPER, 3PT (A64277)
5 SHANK V-RIPPER...
New Landhonor 78" Rock Bucket  (A62679)
New Landhonor 78"...
