4310 seat base spring broken
/ 4310 seat base spring broken #1
chickenman
jd will gladly sell me a new base for $450+ but all i need is a spring
has this happened to anyone here and where can i get just a spring?
/ 4310 seat base spring broken #2
What are the spring specs? Size, length, diam, etc. ??
Do you have a pic?
Do you have a pic?
i only have the seat off so far, i have to get the base off and the broken spring out
/ 4310 seat base spring broken #6
At that Price, you might as well upgrade to air ride.
/ 4310 seat base spring broken #7
I will gladly sell you my one year old spring suspension base for $150+ (I just upgraded to the air suspension). Install this one, use your own base for spare parts. But to be sure it will fit, it's JD part #MIA11339. Hopefully it will fit the 4310
And if anybody needs a forward tilting (hinged and sliding) seat plate - JD #LVA14854 - I've got one that's never been used.
Caution; I just did it, and found out that retrofitting costs ~50% more than if it was OE on the tractor.
//greg//
the spring is 1/4 dia wire, 1 3/8 coil dia, 7 1/2 long over the coil with hooks at each end
i bought a new base from the dealer from an upgrade he did
Heavy Duty Fork Extensions (A65640)
Heavy Duty Fork...
New Three Point Hitch Trailer Mover (A65579)
New Three Point...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
12' x 76" Tilt Flatbed Utility Trailer (A66285)
12' x 76" Tilt...
2004 INTERNATIONAL 4300 4X2 S/A UTILITY BODY TRUCK (A66091)
2004 INTERNATIONAL...
1986 Trailmobile F71T-6UJA 40ft. 32 Ton T/A Flatbed Trailer (A64194)
1986 Trailmobile...
