4310 seat base spring broken
/ 4310 seat base spring broken #1
chickenman
Gold Member
jd will gladly sell me a new base for $450+ but all i need is a spring
has this happened to anyone here and where can i get just a spring?
/ 4310 seat base spring broken #2
What are the spring specs? Size, length, diam, etc. ??
Do you have a pic?
Do you have a pic?
i only have the seat off so far, i have to get the base off and the broken spring out
/ 4310 seat base spring broken #6
At that Price, you might as well upgrade to air ride.
/ 4310 seat base spring broken #7
I will gladly sell you my one year old spring suspension base for $150+ (I just upgraded to the air suspension). Install this one, use your own base for spare parts. But to be sure it will fit, it's JD part #MIA11339. Hopefully it will fit the 4310
And if anybody needs a forward tilting (hinged and sliding) seat plate - JD #LVA14854 - I've got one that's never been used.
Caution; I just did it, and found out that retrofitting costs ~50% more than if it was OE on the tractor.
//greg//
the spring is 1/4 dia wire, 1 3/8 coil dia, 7 1/2 long over the coil with hooks at each end
i bought a new base from the dealer from an upgrade he did
1995 John Deere 7400 (A60462)
1995 John Deere...
378909 (A61166)
378909 (A61166)
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
iDrive TDS-2010H...
2015 Hyundai Genesis 3.8 Coupe (A61574)
2015 Hyundai...
iDrive TDS-2010H...
