4310 MMM Selection
/ 4310 MMM Selection #1
755inNY
Platinum Member
Baldwinsville, NY (10 miles NW of Syracuse)
JD 4310, ehydro, 4WD, R4s
I'm looking for feedback from all the 4310 owners out there with a MMM. 60" vs. 72".
I'm leaning toward the 60" because I think it will go to more places especially when I use the FEL with the MMM still attached. I currently have a 60" MMM on my JD755 so some lawn obstacles have been set to accomodate this width. I mow my pasture with the MMM as years of using the bush hog have gotten it in good shape. The smaller MMM would be a better match for the high grass and uneven surfaces. The savings in mow time between the 72" and 60" is not a factor.
It appears the 60" MMM will be barely outside the the tire tread width (mine will have R4's). Any problems with this?
Anyone with 60" decks that wish they had bigger? Anyone with 72" decks that wish they had smaller (ya, right)?
Any other factors I should consider in my selection?
Thanks for your replies. I'll be ordering my 4310 in the next couple of weeks.
Jeff
/ 4310 MMM Selection #2
I have NO Input on your MMM question. But congrats on the 4310 deal!!! Maybe I can help on some other aspect...
<font color="blue"> Maybe I can help on some other aspect... </font>
rockyridgefarm,
Any input is certainly welcome, below are what I have spec'd:
4310, 4WD, ehydro
Mid PTO
R4 tires
Dual mid and single rear SCV
Power Beyond (in case my neighbor lets me use his 48BH /forums/images/graemlins/grin.gif)
Engine coolant and transmission oil heaters
Forward and rear work lights with brush guards
Automotive cruise and speed match.
MMM
430 FEL with heavy duty bucket and level indicator.
I have been toying with the idea of getting a front mounted snowblower but I don't want to get greedy.
Jeff
/ 4310 MMM Selection #4
Nothing wrong with one deck over the other. I have used both decks. I moved up to the 72" from the 60" to reduce mowing time. I have not found anything with the 72" that would make me want the 60" again. I have found that the 72" deck appears to be a better fit for this size CUT. As stated the 60" just reaches the outside of the back tires. The 72" allows you to reach out and trim closer to objects.
Give it some thought. I went with the 60" and tried to trade it a year later. The better $$$ option was to trade the entire 4310 to get the 72" mmm. I also moved up to a 4410 and the 48BH. A year later my dealer still has my 60" deck.
Craig
/ 4310 MMM Selection #5
I have the 72" mower on a 4200, and selected it for the reasons stated by others... I want the deck to reach out beyond the tires a bit.
In my case, having a 72" mower is overkill for my yard... I can mow the whole thing in 35 minutes... but its the only task I do regularly to put any hours on the tractor (45 hours per year). If I had to do it all over I would not get a belly mower at all. It is too much trouble to put on and off for loader work, and it has trouble sucking up the grass that the front tires run over, leading to streaks. This problem is mainly on bluegrass laid as sod- the seeded grass doesn't seem to have that problem.
Brent
/ 4310 MMM Selection #6
</font><font color="blue" class="small">( It is too much trouble to put on and off for loader work,
Brent )</font>
Brent,
If you had the 60" mower, would you need to take the MMM off to do loader work? I would think it wouldn't get in the way as much, or is there some other reason you take it off.
Cliff
/ 4310 MMM Selection #7
Looks about perfect!
You won't believe it, but I have been looking at *55 models. I'd like to find one with a belly mower to replace my riding mower... /forums/images/graemlins/laugh.gif
But the 4310 STAYS!
/ 4310 MMM Selection #8
I have the 60" MMM on my 4300. I got the 60" because of some small areas around the house. It is a good mower, I mow a lot of grass and sometimes on hot days, I think about the 72", but I will stick with the 60". I have no trouble using the 430 FEL with the MMM on mounted. It is only slightly wider the the wheels.
DPR
<font color="blue"> You won't believe it, but I have been looking at *55 models. </font>
I can't say enough about the 755. After 16 years, I figure it's time to get a new one. It has done a great job but I could use more hydraulic capacity. Don't absolutely need it but there are times....
The hit I'm going to take is mowing the lawn with the heavier weight of the 4310.
Jeff
<font color="blue"> I got the 60" because of some small areas around the house. </font>
DPR,
Thanks for the feedback. Can you mow up tight and around objects such as mowing around trees or landscape beds?
Jeff
/ 4310 MMM Selection #11
<font color="blue"> </font>
Brent )
Brent,
Cliff
<font color="black"> </font>
Sorry, If I mess up this color markup business... never tried
it before.
You have to be real careful when cutting below grade or the width of the belly mower hits the side walls, and I think that would damage the mower. Also, I can't drop the wheels down into the trench for extra depth because belly mower would hang up. I must say that a tractor with belly mower is the smoothest ride one could hope for! The walker mower I ran just about shook me to death if I tried to get anywhere close to it's capacity.
/ 4310 MMM Selection #13
I had the 60'' 7 Iron deck on my old 4300 and it cut great. We also have a 970 with a 72'' deck and that cuts good but not as good as the 60''. The 60'' will be a 7 Iron deck(7 gauge steel) and I don't belive that the 72'' one is. I think it's the standard 12 gauge. The 72'' deck does not have as much suction and does leave streaks in wet, tall grass. The 60'' does not. The 60'' barely stuck out from the 4300 but I think a 4210 or 4310 is a little under powered for the mower if you are going to be mowing thick grass as I do. The 60'' was a good fit but I traded in on a rear mount 72'' for my 990 to reduce mowing time. Both are very good it's how you plan to use it.
/ 4310 MMM Selection #14
If it was me I would get the 72. In narrow situations often there are trees involved anyway and you will need the reach. If I got two tree trunks 60" apart I wouldn't want to mow between those anyway unless I wanted a face full of branches. I'll take reach any day over narrowness.
Of course I would probably go for the RFM anyway since it's cheaper and easier to take off and put on.
/ 4310 MMM Selection #15
I don't have a problem. The mower extends about 4" beyond the wheels. It could be a problem if you have inside curves. we designed with all outside.
dpr
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A61307)
2006 Magnolia Dry...
F-150 4WD (A63689)
F-150 4WD (A63689)
2006 FREIGHTLINER M2 106 T/A BOX TRUCK W/100 PSIG AIR PUMP (A59912)
2006 FREIGHTLINER...
2006 Dodge Grand Carvan Van (A61574)
2006 Dodge Grand...
2015 Jeep Patriot Sport SUV (A61574)
2015 Jeep Patriot...
2025 Spirit Electric Scooter (A61574)
2025 Spirit...
