4310 MID PTO wont work
   / 4310 MID PTO wont work
There are two connectors that plug into the 3 solenoids on the bottom of the tractor and they love coming unplugged by a stray stick that was recently overran by the loader or boxblade. One of the connectors has 2 wires while the other has 4. the connector with 2 goes to the mid pto(front solenoid!). I dont figure there is a backwards way of plugging them in. the middle solenoid goes to the MFWD and it is the bottom 2 pins in the 4 terminal connector. the top 2 pins go to the rearmost solenoid which is the rear PTO. When bounty hunting the problem, I couldnt imagine why there was 3 solenoids down there then theres the question of what do they do? the MFWD slipped past my mind, especially as I was chasing wires and wondering why these two pins were hot all the time? duh the 4wd was engaged! :licking:
   / 4310 MID PTO wont work #22
Thanks for the info.
That is a bit different from my 4300 then. On my connector for the mid PTO, it is position specific. Will only plug in one way.
   / 4310 MID PTO wont work #23
The wires on the soleniods are vulnerable on the 4x10 series tractors. I have been under mine and zip tied the wires as high and tight as I can.
Almost all problems on these tractors should start with a thorough under tractor inspection. BTW Congratulation on the repair!
Im still wishing I could find a skid plate kit! Its actually the rental equipment upgrade. its part #LVB25453 but dono how to make it happen? As for the repair, Im thrilled it came out so simply:thumbsup:
   / 4310 MID PTO wont work #25
Sounds to me like you installed the mid pto improperly and squeal you're getting is you clutches....I'd remove it and check my instructions before something seriously is torn out.
   / 4310 MID PTO wont work #26
Haven't read the whole thread have ya?;)
2023 MDB GREEN CLIMBER F23-80 MOWER (A51406)
2023 MDB GREEN...
2011 INTERNATIONAL PROSTAR +122 6X4 DAYCAB ROAD TR (A54756)
2011 INTERNATIONAL...
2023 54' Hooklift Dumpster 20 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED SDLANCH SDLGC ELECTRIC GOLFCART (A54756)
UNUSED SDLANCH...
2007 MACK CTP (GRANITE) ROLL OFF (A54607)
2007 MACK CTP...
2020 Caterpillar D5K2 LGP Crawler Tractor Dozer (A55787)
2020 Caterpillar...
