4310 MID PTO wont work
/ 4310 MID PTO wont work
There are two connectors that plug into the 3 solenoids on the bottom of the tractor and they love coming unplugged by a stray stick that was recently overran by the loader or boxblade. One of the connectors has 2 wires while the other has 4. the connector with 2 goes to the mid pto(front solenoid!). I dont figure there is a backwards way of plugging them in. the middle solenoid goes to the MFWD and it is the bottom 2 pins in the 4 terminal connector. the top 2 pins go to the rearmost solenoid which is the rear PTO. When bounty hunting the problem, I couldnt imagine why there was 3 solenoids down there then theres the question of what do they do? the MFWD slipped past my mind, especially as I was chasing wires and wondering why these two pins were hot all the time? duh the 4wd was engaged! :licking:
/ 4310 MID PTO wont work #22
Thanks for the info.
That is a bit different from my 4300 then. On my connector for the mid PTO, it is position specific. Will only plug in one way.
/ 4310 MID PTO wont work #23
The wires on the soleniods are vulnerable on the 4x10 series tractors. I have been under mine and zip tied the wires as high and tight as I can.
Almost all problems on these tractors should start with a thorough under tractor inspection. BTW Congratulation on the repair!
Im still wishing I could find a skid plate kit! Its actually the rental equipment upgrade. its part #LVB25453 but dono how to make it happen? As for the repair, Im thrilled it came out so simply:thumbsup:
/ 4310 MID PTO wont work #25
Sounds to me like you installed the mid pto improperly and squeal you're getting is you clutches....I'd remove it and check my instructions before something seriously is torn out.
/ 4310 MID PTO wont work #26
Haven't read the whole thread have ya?;)
STORAGE FEES (A59914)
5' Bush Hog (A62613)
2019 Nissan Maxima Sedan (A61574)
2019 Nissan Maxima...
2023 Kubota U48-5 Compact Excavator with Angle Blade and Hydraulic Thumb (A63689)
2023 Kubota U48-5...
29 x 9.0 x 15 Tires with 5 Lug Wheels (A61573)
29 x 9.0 x 15...
2021 Chevrolet Silverado 2500HD 4x4 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
