4310 Battery Dead?
/ 4310 Battery Dead? #1
HeyNow
West Virginia
JD 4310
My 4310 is three years old now. Last Saturday I was moving some stuff around to the back of the house in the FEL and all was well. Started just fine a couple of times, no problem. I went to start it to move it and ....click...click click. I didn't leave any lights on etc. I got the battery charger out and removed the battery and put a charge on it. It's showing 12 volts and doesn't seem to want to turn over. When I turn the lights on, they do pulsate a bit. Do you think I need to buy a new battery even though I am showing 12 volts?
Thanks in advance for your thoughts.
/ 4310 Battery Dead? #2
Check the battery voltage with your lights on. Sometimes a battery will show 12 volts with no load on it, but as soon as it is underload it drops out.
/ 4310 Battery Dead? #3
HeyNow,
The battery on my 4310 failed in a similar way after 2 years of use. It seemed that all of a sudden and without warning it would not start the tractor. Just click. When I turned on the roll bar mounted lights, the lights would come on dim. I left them on and I could here the battery hiss. After a few seconds the lights got bright but the tractor still would not start. The battery could not handle the load. It probably had shorted plates inside. A good, fully charged battery will read higher than 12 volts.
Because mine was only 2 years old it was prorated against a replacement JD battery.
I think it is time for a new battery. If in doubt, take it to an auto parts store and have the battery tested.
Jeff
/ 4310 Battery Dead? #4
You got 1 year more out of your John Deere battery than I did mine. Mine failed almost 2 yrs to the day.
/ 4310 Battery Dead? #5
A good battery should show about 13+ volts.
Lots of auto parts stores will test it for you.
Or buy a load tester for yourself, they're not that pricey.
I took the battery to our local Battery Mart and they did a load test. The results were not good. So, I bought one of their 60 month brands and dropped 'er in and she fired right up. The only problem has been to find a battery hold down since the new battery does not work with the stock hold downs.
Thanks everyone for your insight.
/ 4310 Battery Dead? #7
my 4310 battery lasted about 2 years replacment was another jd battery so the original hold down is still being used i did not want an aftermarket battery flopping around up front i have seen the damage caused by batterys from not being properly secured.
Metal Bigfoot Lawn Art (A61569)
Metal Bigfoot Lawn...
2020 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2020 Mack Anthem...
Tandem Axle Rear Truck Frame (A59228)
Tandem Axle Rear...
John Deere 2350 Tractor (A61166)
John Deere 2350...
2015 John Deere 3046R Compact Utility Tractor (A63116)
2015 John Deere...
(2) BEST FLEX ROLLER CONVEYORS (A62131)
(2) BEST FLEX...
