4300 VS plow
/ 4300 VS plow #1
DDT
Platinum Member
Clay Center, Kansas
Kubota M6040/cab, BX25D, RTVX900
Has any one pulled a 2-14 plow with a 4300? I have a 1-14 that I used behind a 755 and 855, that was a good match. the 4300 is 1000lbs heaver, about the same weight as the old fords, except I have FWA. I think it should handle it?
/ 4300 VS plow #2
I have a Ford 1910 4WD and I can pull 2-14s and you have more horses. However, make sure plow will specifically fit your tractor so that the right rear tire will ride in the furrow and the plow will cut the 28" to the left. A used 2-14 Ferguson plow wouldn't fit my geometry but a used 2-14 JD did.
RCH
/ 4300 VS plow #3
Here is a link to an article from the LSU Ag Center Research and Extension. tillage equipment hp requirements It covers plows, subsoilers, cultivators, disk harrows, and more. Might be some info there you can use.
This is from that article.
<font color=blue>Drawbar horsepower requirements: Varies widely according to soil type, operating depth, speed and width of moldboard. Usually 15 to 20 DBHP per moldboard at 5.0 MPH.
Four wheel drive tractors should be ballasted to distribute 55 to 60% of the total weight on the front wheels and 40 to 45% on the rear wheels. This weight distribution is recommended for pull type implements.</font color=blue>
DFB
/ 4300 VS plow
I used a freinds dearborn 2-14, or atleast tryed to hook up. I could not get enough adjustment out of it. I about got the first shear where i wanted it but noticed the left side of the plow frame was agaist the left 3 point arm, If it was my plow I could fix it with a smoke wrench. Did not think he would like that. Most plows are adjustable, the bott pins can be moved over to acount for wider or narrower rear tire width. 2-14's are not easly found in my area, I will have better luck finding a 2-16. I just can't bring myself to buy a new $600 plow when the old ones sell for $100 at auction's. Thanks for the insight!
Hey that is a neat site, glad you posted it.
DDT
10in Digging Tooth Bucket Excavator Attachment (A64194)
10in Digging Tooth...
2005 MACK CV713 MIXER TRUCK (A65643)
2005 MACK CV713...
2014 Doyle Dry Fertilizer Tender Trailer - Kubota Diesel, 3 Stainless Compartments, Side Discharge (A61307)
2014 Doyle Dry...
2022 EZ-GO ELITE...
2022 SWARTZ 100" X 40' GOOSENECK TRAILER (A64276)
2022 SWARTZ 100" X...
Excavator Grapple (A64127)
Excavator Grapple...
