430 Broken Front Wheel Spindle
/ 430 Broken Front Wheel Spindle #21
Below your post, see if you have an Edit Reply Reply with Quote ... should be there. Click the Edit one
/ 430 Broken Front Wheel Spindle #22
I cut mine off and installed new axles with standard trailer bearings so I could use HDAP tires all round.
/ 430 Broken Front Wheel Spindle #23
/ 430 Broken Front Wheel Spindle #24
I realize that this thread is over four years old, but I had the same exact problem a few years ago. The left side spindle broke off just below the washer welded to the spindle where it goes into the axle. I found a pair of used spindles on Ebay, but they were from a different break in serial numbers and were metric instead of inch and wouldn't fir the axle bushings or wheel bearings. Sooooo, I found another set that were correct and bought them. They were the correct size and worked fine.
I think it's a poor design for a piece of bent metal rod to support all the weight the 430's have on their front axle. That is one reason I never got an FEL for it, the front end just didn't look like it was up to it.
/ 430 Broken Front Wheel Spindle #26
I had the left one break also, about a year ago, much to my surprise a replacement was available from my local JD dealership. Amazing you can still get most of these parts new.
John Deere 544K Articulated Wheel Loader (A64553)
John Deere 544K...
6 Band Wood Barrel (A64557)
6 Band Wood Barrel...
2018 Roadtec RP190E Highway Class Wheel Asphalt Paver (A64553)
2018 Roadtec...
🚜 2022 Mahindra 1635 HST Tractor Package – ONLY 36 HOURS – FULL SETUP READY TO WORK!
🚜 2022 Mahindra...
YALE FORKLIFT (A63291)
2018 CATERPILLAR 320GC EXCAVATOR (A65053)
2018 CATERPILLAR...
