430 Broken Front Wheel Spindle
/ 430 Broken Front Wheel Spindle #21
Below your post, see if you have an Edit Reply Reply with Quote ... should be there. Click the Edit one
/ 430 Broken Front Wheel Spindle #22
I cut mine off and installed new axles with standard trailer bearings so I could use HDAP tires all round.
/ 430 Broken Front Wheel Spindle #23
/ 430 Broken Front Wheel Spindle #24
I realize that this thread is over four years old, but I had the same exact problem a few years ago. The left side spindle broke off just below the washer welded to the spindle where it goes into the axle. I found a pair of used spindles on Ebay, but they were from a different break in serial numbers and were metric instead of inch and wouldn't fir the axle bushings or wheel bearings. Sooooo, I found another set that were correct and bought them. They were the correct size and worked fine.
I think it's a poor design for a piece of bent metal rod to support all the weight the 430's have on their front axle. That is one reason I never got an FEL for it, the front end just didn't look like it was up to it.
/ 430 Broken Front Wheel Spindle #26
I had the left one break also, about a year ago, much to my surprise a replacement was available from my local JD dealership. Amazing you can still get most of these parts new.
2016 Freightliner 108SD Truck (A64194)
2016 Freightliner...
2019 JOHN DEERE 331G SKID STEER (A65053)
2019 JOHN DEERE...
2012 Kenworth T800 T/A Sleeper Cab Truck Tractor (A64194)
2012 Kenworth T800...
2014 KENWORTH T370 ROAD TRACTOR (A64280)
2014 KENWORTH T370...
2008 Nissan Xterra SUV (A64557)
2008 Nissan Xterra...
2022 EZ-GO ELITE...
