425 - model year changes and price check
   / 425 - model year changes and price check
He is telling me he is the second owner and it came with the fan missing. Seemingly, he didn’t even realize one should be there, unless he’s full of it.
So, it has definitely been used without the hydro cooling fan, but no way of telling if it has been used hard. I suppose if it was not used hard without the fan, it could be a non issue. Good points on checking the hoses near the cooler / engine and the smell and color of the hydro oil.
Does anyone know if a 2012 machine has the upgraded wheel motors?
   / 425 - model year changes and price check #13
If I remember correctly, it had a worn 2nd set of tires. This shows hard use to me.
When parts break and the owner doesn't fix it (cooler), this shows they will skimp on everything else, like high quality oil and oil/filter changes (hyd filter interval is 50 hours).
I use a magnetic temp gauge for hydraulic oil on all 3 of my PTs. On a hot summer day, after hours of work, I still switch off to something else due to high oil temps. This is most noticeable in loss of torque in the drive motor circuit on my 1430 when using a flail mulcher in the woods (and climbing over rocks etc).
The removal of the cooler parts would be a deal breaker for me, unless your just using it for a wheel barrel and don't have high expectations. But you might end up finding it is the most useful machine in your arsenal and might regret not buying one in the best condition to start with (that is how I ended up with 3).
   / 425 - model year changes and price check #14
Ask Terry and PowerTrac - he knows everything.
800-843-9273
Don’t ever hesitate to call him.
Truly a great guy and wants to help.
My 425, purchased new in 2013 had them and I was told model was unchanged in the few years prior.
I also have an older 4xx and it did not have the larger motors. Definitely a difference.
   / 425 - model year changes and price check #15
Are you interested in the land aerator?
Thanks
Stuart
   / 425 - model year changes and price check #16
...Has anyone raised the relief valve pressure on these to increase the loader lift? 800lbs of lift is decent for the machine's weight, but I always seem to push my loaders to the edge one way or another.
Thanks in advance for any insight / info!
As others have mentioned, the unit will lift the rear end off the ground easily if there is enough weight on the FEL arms. Upping the relief valve pressure will do nothing for you at all. I've never hit the reliefs on my 2001 PT425. The rear comes up first. I also wouldn't add weight to the rear of the machine. While that will increase the lifting capacity, it'll also put more weight on the front wheel motors AND more weight on the points were the articulation joints attach the front and back halves of the machine. But, that's just me. ;) (y)
   / 425 - model year changes and price check #17
Click on photo attached for PT Pucker (rear end lift).
   / 425 - model year changes and price check #20
A 425 is rated for 800lbs, but will lift 1000lbs. At least mine will. For a 1300lb machine, that is an exeptional lift capacity to weight ratio. I have set boulders in retaining walls with this machine that were most likely pushing 1200lbs. The "PT Pucker" allows you to lift more than the machine should be able to.
The center section of the machine is composed of a top linkage rod and a bottom ball joint. The bottom ball joint is held in place by two split rings. One top and one bottom. When you lift a load, alot of that stress is transferred to the top split ring. As best I can tell, this is the weak point of the center section. If you try to increase the lift capacity beyond what it will currently do, you might consider welding a bushing in place of the top split ring.
Hope this helps
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
2019 BOBCAT T595 SKID STEER (A52707)
2019 BOBCAT T595...
MODERN AG PRODUCTS 5' ROTARY MOWER (A57192)
MODERN AG PRODUCTS...
2012 DOOSAN G25 GENERATOR (A53843)
2012 DOOSAN G25...
2022 RAM 2500 HEAVY DUTY (A55745)
2022 RAM 2500...
Mini Margaritaville Truck (A55853)
Mini...
