Yep..... ditto.
I am really **** about 3 things with my 4231TD.
1. Never let it overheat!!! Clean the radiator screen as soon as the temp hits 200. Blow out the radiator with an air line frequently.
2. Do all the maintenance. Do the oil changes. Keep the air filter clean.
3. Let the turbo cool down before shutting it off. When I clean the radiator screen, I shut it off very quickly, and restart as soon as I pull it out.
Follow these three pointers, and your diesel will last a long time.
I would tend to agree with you under normal circumstances,...however the 31TD is a problematic engine...its not likely to make 2000hrs at all,and not likely to make 1000 without a major repair(turbo,cracked head,thrown rod) I hope you prove me wrong...whatever the difference in gas (at 3.69 here now) and diese (4.29). It isnt worth it unless your unloading it in a few seasons,the gasser will last forever,and cost you little to keep up.My dealer doesnt recommend the 31TD and tries to get people into the 26.5 diesel,at least it will make 1000hrs trouble free and maybe even 3-4K total....he showed me a stack of heads and turbos off 31 turbodiesels in the corner and ventilated engine blocks most with under 1000hrs.....trust me i wanted the 31TD,he talked me out of it,and since then ive done extensive research and found his findings to be spot on.Google it and find out how many people have had major problems with that engine at low hrs,and were denied warranty without justification.
Ive found the 31 gas impossible to overheat so far,ive had the screen blocked 3/4 of the way with grass when cutting my field(over a foot tall) ,depending on the wind it can clog in 5 minutes,I never stopped to clean it,it runs 185 normally,and ive never seen over 190 in the most severe conditions...my dealer says even with the best maintenance and cleaning,the 31TD will overheat on hot days in heavy conditions,and most operators will not stop,they keep going...the 26.5 diesel will not overheat in the same conditions....neither will the 31gas...with a 25K machine that shouldnt be,and with multiple operators i see this as a reason Id never buy the 31TD.Way to easy to ruin a 5000 engine. I wish you the best of luck with yours,and if it were mine,Id run Shaeffers x9000,(5w40) in the engine,for added protection especially for the turbo,and Id run a bottle of redline watter wetter in the cooling system,it should help you knock 5 degrees off your peak temps...not much but it helps...
