422 won't start
/ 422 won't start #1
scarg
Bronze Member
Upstate NY
PT 422 Mod to kawi 29HP FD791
422 won\'t start
I had a problem starting the PT422 this morning. I sent an email to PT however I began troubleshooting with Captain Obvious after reading a few post here in the forum.
Past history - when i first received the 422 i posted some messages about the engine stalling when bush hogging.
The problem mysteriously went away.
Lately however i have been noticing the unit not having much power when mowing uphill. Even up slight grades.
Present problem- motor would turn over but not start-
I checked for spark in spark plugs and all was well.
I removed heat sheild to check fuel filter and there was a small amount of debris but not too much.
I traced the fuel line back from the fuel pump (i think that's what it is?) to the bottom of the gas tank. That is where i noticed that the gas line had been routed directly between two stiff hydraulic lines. The line had completely squeeze the fuel line together.
After recharging the drained battery from all the startup attempts the unit fired right up and runs swell!
Just posting to maybe help someone out in the future.
Best regards,
Steve
/ 422 won't start #2
Re: 422 won\'t start
Good job on the trouble shooting. /forums/images/graemlins/laugh.gif
/ 422 won't start #3
yes good job on the trouble shooting and thanks for posting the solution!! /forums/images/graemlins/grin.gif
Caterpillar C18 Industrial Diesel Engine - Serial N8F01120 - Power Unit - Pump Takeout (A63689)
Caterpillar C18...
2025 Fendt 1167 Vario Tractor (A63111)
2025 Fendt 1167...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
2021 CATERPILLAR 279D3 SKID STEER (A62129)
2021 CATERPILLAR...
2016 Ford F-150 Crew Cab Pickup Truck (A59228)
2016 Ford F-150...
2019 INTERNATIONAL LT625 TANDEM AXLE SLEEPER (A59575)
2019 INTERNATIONAL...
