4200 HST with shift fork problems
/ 4200 HST with shift fork problems #1
hth
Bigfork, MT
John Deere 4200
I have a 4200 HST and it only works in C range. When I select A or B range it remains in neutral and goes nowhere. How hard is it to replace the shift forks and is there anything else I can try to get me running again in A range? When I talked to the dealership they said they would need to split the tractor and it would be at least 15 hours of work - not something I want to pay them for if I can do it myself or there is an easier fix. All the linkage on the outside is good and it shifts easily. I am fairly good as a mechanic i.e. I have replaced a timing belt and turbo and various other car parts but I have not worked on any transmissions.
Thanks for your help!
/ 4200 HST with shift fork problems #2
Get a workshop manual if you are going to do any work on your machine. Splitting a tractor is a lot more than a timing belt. You have a couple thousand lbs parts to properly support while you pull them apart.
Most things clutch related & a lot of transmission stuff requires splitting on most tractors.
/ 4200 HST with shift fork problems #3
Look up some threads on here about splitting tractors. Usually complicated and requires a fair amount of dedicated space.
/ 4200 HST with shift fork problems #4
You may be in luck. Sort of.
The range shifter rods commonly break, and I suspect yours has broken while you are in
the high range. It CAN be replaced without splitting the tractor, but you will have to
remove the 3-pt cylinder housing on top. I have it documented somewhere on TBN.
/ 4200 HST with shift fork problems #5
I have a PDF of the Deere technical manual that you're welcome to.
If wanted shoot me your email
Joe
/ 4200 HST with shift fork problems #6
Did you ever find what was causing no A or B range? What was the fix?
Multipurpose Skid Steer Mount Backing Plate  (A62679)
Multipurpose Skid...
2025 32in. Tilting Bucket Mini Excavator Attachment (A64553)
2025 32in. Tilting...
2019 FREIGHTLINER M2 4X2 S/A 26FT NON CDL BOX TRUCK (A59914)
2019 FREIGHTLINER...
John Deere Metal Sign (A65583)
John Deere Metal...
2019 ISUZU NPR 16FT 4X2 S/A REFRIGERATED BOX TRUCK (A59914)
2019 ISUZU NPR...
John Deere 2755 Tractor w/ Boom Mower (A66285)
John Deere 2755...
